Negative voltage on the positive rail, what's the damage??
Thread Tools
Old 28th November 2020, 01:43 PM   #1
A 8 is offline A 8  Sweden
Default Negative voltage on the positive rail, what's the damage??
Not sure if or how it happened but assuming I accidentally got negative voltage on the positive rail in a trad AB amp what would the damage be?
Old 28th November 2020, 03:19 PM   #2
adason is offline adason  United States
adason's Avatar
electrolytics?
Old 28th November 2020, 07:07 PM   #3
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Insufficient data.
Is it a single or dual supply amp?
IF split supply, you inverted both rails or just connected negative supply to amp positive leaving amp negative disconnected?
Or any other combnation?
In any case, you have the amp in your hands, YOU tell us the damage you see.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 28th November 2020, 07:38 PM   #4
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
If you connected neg rail to pos rail then probably would just blow fuses.
If rails got swapped then its like a few semiconductors would get taken out.
2021 versions of PCBCAD51 and PCBCAD720 out now >>> https://www.murtonpikesystems.co.uk
Old 28th November 2020, 08:18 PM   #5
rayma is online now rayma  United States
Post the schematic. Are you sure that the meter leads weren't just reversed?
Old 28th November 2020, 08:58 PM   #6
I doubled up on the transformers after the rectifiers to the same capacitor bank driving both channels. After paralleling the transformers on the dc side of the diod bridges and powering up the amp through 10 ohm resistors on each rail the amp seemingly shorted the positive rail on both channels burning the 10 ohm resistors.
Reversing the change still seemingly shorts the positive rails and on one channel puts a lot of DC on the output so something went wrong/broke.
The only thing "off" with my paralleling attempt was the phase being reversed before the rectifier on one of the four diod bridges but I did not think that would be a problem as I was using the dc side on the diod bridge. Obviously I missed something and when measuring the residual voltages on the rails I had a slight negative on the positive rails hence the assumption or the amp had gotten the wrong polarity on the plus rail even though I don't understand how.
The question/ask for help was to try and understand if a temporal negative voltage on the positive rail could explain the now shorting behavior of the positive rail.
Old 28th November 2020, 09:36 PM   #7
MarcelvdG is offline MarcelvdG  Netherlands
Most integrated circuits get fried when you put more than one silicon diode forward voltage in the wrong direction between the positive and negative supply rails. In a discrete circuit, anything can happen depending on the exact circuit.
Old 29th November 2020, 12:54 AM   #8
MarsBravo is offline MarsBravo  Netherlands
MarsBravo's Avatar
...I missed something...
Yeah, water is wet, no matter if you believe it or not (at room temperature).
The thought is ok, double the power supply and more power is available for the amp, but that's not working.
I've the impression you've killed the supplies (maybe the transformers but surely the greatz-bridges and...) so better have the supply in good condition before connecting it to other circuits. As said above, all semi's & large caps are suspicious now. This is valuable learning money (be proud!). Welcome to the Incineration Club.
Y/Yo=(1-X/Xo)exp2 <> Y/Yo=(e)exp(X/Xo){Xo=kT/q}
Old 29th November 2020, 03:32 PM   #9
Yes its probably fried even though the caps seem ok and at least 2 of the diod bridges.
I swapped the output transistors Sanken SC2922/SA1216 and things changed, now seemingly shorting both rails.
I still don't get what went wrong, the transformers and bridges were identical in terms of make and model and I've seen many designs that double transformer windings this way ie on the dc side of the diod bridges. In fact I have another one that runs this way albeit this one has two different voltages, on +-30 and the other -+40 but I don't see how that makes a difference as in my case one will be slightly lower than the other.
Old 29th November 2020, 11:25 PM   #10
MarsBravo's Avatar
That's 25% difference... fatal. Just 1% diff starts heating things up already.
Negative voltage on the positive rail, what's the damage??Hide this!Advertise here!
Thread Tools
Positive power supply rail at a different potential than negative rail? The Lord Flashheart Car Audio 87 9th June 2020 03:27 PM
on chip negative voltage regulator with positive supply voltage gvsrkprasad Power Supplies 3 20th February 2013 03:19 PM
comining rail to rail and rail to ground decoupling? jazz Power Supplies 2 30th March 2010 02:13 AM
Positive regulator to produce negative voltage? stef1777 Parts 45 8th February 2008 08:46 AM
Small voltage deviation at positive and negative rail 2Bak Chip Amps 1 14th December 2003 07:42 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
