Stability of an amplifier under capacitive loading
Thread Tools
Old 17th September 2020, 01:33 AM   #61
mjona is offline mjona  New Zealand
@knutn,
There are some differences between your simulation in comparison with a Tian plot. There are some examples of this such as here OITPC - Output inclusive TPC (not TMC)
Old 17th September 2020, 09:37 AM   #62
knutn is offline knutn  Norway
i have tried a simulation with KSA1381/KSC3503 and compared to the BD-types, the difference is very small. As long as I have not observed any stability in the built amplifiers (I have made 4 channels), I think the Miller capacitors are large enough.
Old 17th September 2020, 09:51 AM   #63
duncan2 is offline duncan2  United Kingdom
I was interested in the comment about inter-electrode capacitance in a BD139 and the comment that it could vary from manufacturer to manufacturer .
I could not find any actual info online when it came to the specifications by various companies but came across this-
Application Note No.024 by Infineon which is interesting -
AN024.fm - Parasitic_Capacitances_Bipolar_Transistors_AN024_I nfineon.pdf
Old 17th September 2020, 09:40 PM   #64
N101N is offline N101N
It is utterly reprehensible to call the indispensable interelectrode capacitances parasitic. Choose transistors with appropriate interelectrode capacitances for the task. The need for phase compensation is a palpable sign of functional disorder and design failure.
Old 17th September 2020, 10:08 PM   #65
N101N ---if you feel so strongly about the AN of this company why don't you complain to them not me ?
I am sure they will "react " to your criticism , in a perfect/ideal world there would be no capacitance between elements but we are still waiting for the Klingons to land on earth with their "capacitance cloaking device " and put things right on planet earth.
An old English fable has King Canute standing at the sea edge saying " I am King and I command the tide to go back "----it refused and wet his feet --naughty tide ! That was in the 12th Cent. --nothing has changed .
Those statistic are needed in many engineering situations some vital .
Old 17th September 2020, 11:48 PM   #66
I was not complaining to you. A larger amplitude naturally conveys a larger current. The alternative is saturation, a nonfunctioning transistor.
Parasitic capacitances can be unintentionally added in the process of manufacturing, but that`s something else.
Old 18th September 2020, 09:08 AM   #67
I think it's better to deal with parasitic capacitances than with Maxwell's equations...
Old 18th September 2020, 09:12 AM   #68
Parasitic capacitance or to put it more gently --"stray capacitance " is a natural occurring engineering phenomenon as we have not reached the stage of perfection.
When an engineer calculates the design of a tube/BJT/Mosfet etc etc this has to be taken into account when designing an electronic component .
Can you explain or show where "Perfect " components are manufactured in this world ?
Or are you complaining about the English grammar as being faulty ?
I could post long lines of university maths on this but will just post a Wiki explanation that keeps it simple.
If a Standard of perfection had been achieved then you could base your point on that , but it hasn't, people like engineering are not perfect.
A capacitor has resistance/capacitance/inductance --even a resistor contains other elements.
Parasitic element (electrical networks - Wikipedia)
Old 18th September 2020, 03:18 PM   #69
spladski is offline spladski  United Kingdom
Devices have capacitance. Less concerned what they are called. This is a more interesting comment.
Isn't that a bit harsh? A means to an end?
Old 18th September 2020, 04:15 PM   #70
Anyway, for the BD139, we can firmly expect humongous nonparasitic interelectrode capacitances and parasitic stray capacitances making it unsuitable as a voltage amplifier.
spladski,
I want to call it a clear-cut formal announcement.
Stability of an amplifier under capacitive loadingHide this!Advertise here!
Thread Tools
New Amplifier Build Stability H713 Solid State 37 15th May 2020 09:20 AM
SMPS - Capacitive loading knutn Power Supplies 19 27th August 2019 10:40 PM
Stability into capacitive loads aros71 Tubes / Valves 8 23rd July 2017 06:34 AM
"Tuning phonograph reproduction...capacitive loading & channel balancing" RCAguy Analogue Source 0 3rd March 2015 04:57 PM
good ESL amplifier that works with extreme capacitive loads thadman Solid State 2 1st February 2007 12:20 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
