Yamaha RX-V 2500 idle temp
Old 1st August 2020, 02:54 PM   #1
tojoko is offline tojoko  Netherlands
Default Yamaha RX-V 2500 idle temp
Hi
I bought a used RX-V2500 and wanted the fan to be acrive sooner, before the amp becomes too hot, a few years ago I read an article of a guy who put in a resistor, that makes the fan coming in quicker, but I can not find the link any more, if you give it in in Google search, you are being directed to a weird website, nothing to do with this article, has anyone saved it by chance?
Thanks for any info on that.
Tojoko.
Old 1st August 2020, 06:22 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
The fan is fed from pin 4 of IC501. IC501 senses the temperature and there is no change of resistor to be done. It is written into the chips programme.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 1st August 2020, 06:56 PM   #3
Mooly's Avatar
This link works for me if it is what you want:
Lowering the Idle Temp of Yamaha RX-V2500
Old 2nd August 2020, 09:39 AM   #4
Default RX-V2500
Hi
Thanks, that was the article I was looking for,
Will use it in multichannel (8) mode for my diy active 3 way speakersetup, using a Najda digital crossover, it will be my second setup, alraedy got a setup like this one going for several years now, really good! 6 poweramps and the volume control used in the Yamaha, can not go any cheaper, when going active, paid 90 dollars for the (very good) Yamaha
Cheers, Tom.
Old 2nd August 2020, 09:48 AM   #5
Mooly's Avatar
OK Good luck.
  Reply to this post
Yamaha RX-V 2500 idle tempHide this!Advertise here!
temp grounding rock12 Tubelab 2 15th February 2013 08:48 PM
old school performance teknique 2500+2500 timwebb Car Audio 4 9th April 2012 03:34 PM
Temp job Nixie Everything Else 41 24th February 2007 11:28 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
