Repair Onkyo SR508
Repair Onkyo SR508
Old 9th July 2020, 11:11 PM   #1
staze is offline staze
Default Repair Onkyo SR508
My mom dropped off her SR508 for me to repair. Found shorted output transistors on the back left. Wonderful person in this thread Replacements for SA1941 and SC5198 helped me out with some replacement output transistors. Got those replaced. Also replaced open emitter resistor on those output transistors.
Then found fuses to amp board were blown. Replaced those.
Unit now shuts down after power up. Found the emitter resistor on one of the drivers was blown (open, should be 100R). Replaced that (temporary currently since these amps SUCK to get the main board out of.
Unit is still shutting down for some overload. Thermal camera shows the output transistors and emitter resistor for them getting hot. But they seem fine (no shorts I can find). Driver transistors seem fine as well.
I don't get where else to look. Unit powers up for maybe half a second (I can see a voltage across the P6085 plug, but it doesn't seem to respond much to turning the trim pot. hovers right around 4.6V. Which is obviously super high since it should be down around 2.5mV. So either something is shorted, (one of the output transistors even though they seem fine), or something is driving the outputs fully on.
Any thoughts? On the plus side, at least the board is well labeled.
Old 10th July 2020, 08:20 AM   #2
mbz is offline mbz  Australia
With 4.6V across emitters, suggest work back checking voltages at transistor bases until you find a normal/expected voltage. Check Q6035, 6045. Second thought, maybe measure either side of R5135 to GND, repeat for R5205, these more or less connect to base of Q's. Might come back to Q5045 failed open?
Old 11th July 2020, 07:46 PM   #3
So across both R5135 and R5205 (individually) I only get 12K. And no evidence of charging a cap. I can see there's a parallel path through R6055, R6015, R6055, and R6035, and that does SEEM like the 12K is reasonable, I think? Though maybe not if I'm measuring them individually as opposed to singularly.
Measuring the same circuit on the other channels start out around 12K but I can see the charging as it climes to over 13.5K.
Seems like I'm gonna be stuck pulling the board. Which complicates testing, sadly, but will make it work. Will also check the base's of the transistors.
Old 13th July 2020, 06:58 PM   #4
Holy hell the soldering on these amps is awful (and the heat cycling doesn't help). I've found so many joins that look cracked/dry, and a few that definitely were...
Slowly going through and fixing them all, but not sure that would cause this. I'm not seeing any base voltages at all when I'm checking down the line and the unit briefly powers up. =/ which makes me think the output transistors are bad... or I'm missing something super obvious.
Old 14th July 2020, 12:34 AM   #5
Trying to make sense on my last post re:R5315. The idea was to measure transistor base voltages at drivers and then work back until you find an expected voltage as per the schematic. So, need to measure Vdc to CND at Q6035base. Repeat for Q6045b, expect +/- 1.2Vdc. Suggest diode check Q5045(? schematic not real clear, emitter connects to R5175)
Also measure Vdc Q5045 b/c/e to GND
Old 14th July 2020, 03:09 AM   #6
Thanks! So, none of them are right all the way back to Q5055.
All are base to ground vdc. All are also best guess since the unit only powers up for about 3/4th second. So nothing is stable. Can fire up my scope if we need quicker values.
Q6035: 3.8V
Q6045: -3.8V
Q6015: 4V
Q5035: 11.3V
Q5045: -11.3V
Q5055: -11.3V
Q5045 diode check (pos on left, neg on right):
B-E .6V
B-C .6V
E-B .56V
E-C .689V
C-E OL
C-B OL
Q5045 to ground:
E-GND: -12V (maxes briefly at -14V)
B-GND: -12V
C-GND: -3.9V
Old 14th July 2020, 03:15 AM   #7
Here's a hopefully higher res screenshot of the service manual. I can upload the SM if that's allowed (I'm unsure).
Old 14th July 2020, 06:25 AM   #8
Voltages appear mostly symmetrical, eg, Q6035b, Q6045b +/-3.8V.
Q6015b=4V appears to be the odd man out, wondering if that timmer(R6045) is ok. Check solder connections on trimmer and Q6015, diode test this Q.
Old 14th July 2020, 07:07 AM   #9
OldDIY is online now OldDIY
Q6045 strange voltage base-emitter. Collector breakage?
Old 14th July 2020, 09:28 AM   #10
The schematic in post #7 is much better, thanks.
Assume that you diode tested Q6045 in circuit, the abnormal results due to alternate paths?
Repair Onkyo SR508Hide this!Advertise here!
help with Onkyo 7.1 repair ivoh Solid State 16 28th December 2014 12:43 AM
Help fixing Onkyo TX-SR508 CFassoni Solid State 1 1st October 2014 12:56 PM
Got Onkyo M-504 amp out of repair yay! 2 Q's saabracer23 Solid State 10 6th September 2014 01:14 AM
FS: SACD Players (Yamaha S1800BL, Denon 1930CI, Sony S9000ES) and Onkyo TX-SR508 Rcvr zxgravediggerxz Swap Meet 9 17th December 2012 06:44 AM
DIY Repair of Onkyo TX-SR875 josha Everything Else 0 10th January 2011 08:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
