High power Germanium power amplifier (any thoughts??)
Old 3rd July 2020, 09:21 PM   #41
CaterpilarSK is offline CaterpilarSK  Slovakia
Originally Posted by OldDIY View Post
Thats more like what I was looking for. Simple and appears to be effecitve enough. Just a bit worried the feedback will delete or nulllify the mumbo jumbo of the germaniums. Oh well Ill try and create
Old 4th July 2020, 01:38 AM   #42
yeti is offline yeti  Germany
In the time of germanium transistors PNP was king.. TO3 Transistors had a3mm thick copper housing.Base to emmitter voltage was about 0,3 V. Still nowadays they use germanium Diodes for HF rectification..low threshold voltage and smooth transition from non conducting to ON similar to a thermionic tube. The problem was .. if a germanium transistor reaches a temperature above 75 degrees centigrade it will thermally runaway into selfdestruction.At ambient temperature of..say 35 degrees you have another 35 until failure, with silicon in TO3 you have 200 degrees to failure thats a margin of 165degrees. whats it about: you can replace low power AC or OC..(germanium transistors) by BC or 2SA 2SC(silicon transistors) by doubling the value of the resistor thats between the base and the emitter. if there is AA118 or like that..try a schottky diode.
Old 4th July 2020, 03:05 AM   #43
OldDIY is offline OldDIY
Forum ?????? "?????? ???????????"
Registration required to view diagrams.
High power Germanium power amplifier (any thoughts??)Hide this!Advertise here!
High Voltage BjT's for Pre-driver stages of High Power Amplifier - Overview tiefbassuebertr Solid State 74 11th May 2020 09:55 PM
A High-Quality, High-Power Headphone Amplifier gdan Headphone Systems 20 12th April 2019 02:46 PM
The Wire - Low Power Ultra High Perfromance (LPUHP) 16W Power Amplifier opc Solid State 755 8th January 2018 07:55 PM
High Power, High Fidelity Lateral MOSFET Power Amplifier sasek Solid State 2 28th November 2012 03:59 AM
LF: The Wire - Low Power Ultra High Perfromance (LPUHP) 16W Power Amplifier jtktam Swap Meet 0 3rd May 2012 09:59 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
