Hi Jim,
Had a similar problem with mine. The bias link across R456 had gone o/c, burning out R456. Unfortunatley mine went +VB (33V) at output, therefore burning out the voice coil of the R/H speaker, an old Tannoy HPD315.
Having repaired the amplifier (i still don't really trust it), it works fine. i need to get one of me valve amps going - no chance of DC output from an output transformer, eh ?
The NAD 302 is a nice design but in my humble opinion far too complicated. i far prefer MOSFET to bipolar trannys.
Attached is the service manual.
Neil xx.
Neil xx.
Thanks for the circuit Redbeard --hifi engine thinks I am a bot .
Your right this is no NAD 3020 which I have in my room somewhere .
Yes I too prefer mosfets to BJT,s --as per JLH , you may not know it but that started a "war " on EW between D.Self and JLH --sides were taken .
Its also the preferred output devices of a well known Italian audio design engineer who put in his point of view with various high slew rate power amp circuits.
No worries, duncan2,
i rather like NAD stuff. Although it is cheap (well, inexpensive), NAD have clearly put in a very great deal of R&D time into their amps.
Their 3020 which you have is a classic. The right amp at the right time for the right price. The first NAD i got (before the ill-fated 302) was a 310 from a local guy off a well known auction site.
A very peculiar power amp circuit, half MOS and half BJT and relying on a giant electrolytic to decouple the output. Intriguing sound, which is strangely involving. Replace supply capacitors and output coupling capacitors if you try one.
Being a valve guy, i only bought the NAD 310 as a temporary replacement for my 6080 power amp which i failed to simplify (removing the first gain stage {ECC82 anode-follower, gain 12}, outside the feedback loop and upping the gain of the phase splitter and driver stages) - not enough gain. Reduced the ammount of feedback to up the gain, which worked but it sounded shiite. No bass control.
So i bought a cheap NAD 310. Sounds great but has an unusual output stage. Bought a NAD 302 due to it having a more symetrical output stage, with results as stated in post #6.
Although it's completely off-topic, and i will be criticised, have you ever considered trying depletion-mode MOSFET's in a power amp ?
i never have but like the way they should bias, kinda like a JFET or a valve ?
Neil xx.
Neil xx.
No sorry Neil I have never tried Depletion mode MOSFETS although JLH gave a warning about the Lateral ones as being "tricky " to keep stable .
Yes the bias is different and the bias circuit has to be designed differently and your right "more like a valve ".
An introduction to Depletion-mode MOSFETs - IntroDepletionModeMOSFET.pdf
Hi big jim,
Yes, the 302 was a later circuit but not, i believe, based on the 3020. See attached service drawing. The 3020 used the old TO3 2N3055 and 2955 output transistors and is a far simpler circuit.
More difficult to mount (a TO3-P would have been easier, had they existed back then). The 302 is also significantly more complicated.
All the best,
Neil xx.
All the best,
Neil xx.
Cheers duncan2,
i'll give that article a read later on. Maybe not biased "like a valve", more like a JFET ? Same thing really. Grid or Gate at Cathode or Source potential = it's fully "on", Grid or Gate at lower than Cathode or Source potential it turns gradually "off".
Perhaps making them good as a constant current source or sink ?
All the best,
Neil xx.
All the best,
Neil xx.
- NAD 302 Repair
