Sugden original A21 preamp voltage?
Old 29th June 2020, 02:11 PM   #1
dixikatt is offline dixikatt
Default Sugden original A21 preamp voltage?
Does anybody know what voltage feeds the preamplifier in the original Sugden A21. The power supply has been altered by a previous owner so I have to sort it out to get it working again after a rectifier failure.
Old 29th June 2020, 03:07 PM   #2
duncan2 is online now duncan2  United Kingdom
How original its goes back a long way IE-1968 ?
Scroll down for spec.
Sugden A21 Series 2 amplifier | Hi-Fi News
Old 29th June 2020, 09:07 PM   #3
To be more specific, it is the Series 2 model
Old 29th June 2020, 09:25 PM   #4
That being the case MM=2.5mv. into 68Kohms ? SN 70db down
Radio/Tape/Aux/=150mv into 200Kohms--SN 80db down
Ceramic=50mv
FR=+/- 1db --- 30hz to 20Khz
Thats the ORIGINAL model in my link.
Old 29th June 2020, 09:38 PM   #5
I'm sorry not being specific enough, I mean the power supply voltage for the preamp.
Old 29th June 2020, 10:16 PM   #6
OldDIY is offline OldDIY
Up 32 V Облако Mail.ru - облачное хранилище файлов
Old 29th June 2020, 11:08 PM   #7
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Thanks for posting but I can only see a Cyrillic written page which is probably telling I have no business being there
Canīt you just post that image here, so it opens inside the answer itself?
Thanks.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 30th June 2020, 04:22 AM   #8
Supplies to a preamplifier, if required, are taken from the 36 V rails and stabilised to 16 V with the Zener
diode. The zener diode also has in parallel a 1,000 uF capacitor to provide additional ripple smoothing.
https://sound-au.com/tcaas/sugden10w.gif
Old 30th June 2020, 06:51 AM   #9
Option Richard Allan A21
Richard Allan Class A amplifiers
Old 30th June 2020, 10:24 AM   #10
So it is 16v, thanks for your contributions.
Sugden original A21 preamp voltage?Hide this!Advertise here!
Which cap select for a Sugden Au41 preamp randomproblem Analog Line Level 8 13th September 2019 12:56 PM
recapping using caps with much higher voltage value range compared to original specs robert2017 Solid State 290 16th September 2018 02:20 AM
Low voltage vs. High Voltage Preamp. rcollege Tubes / Valves 43 25th February 2013 06:02 PM
FS: Original Millett Hybrid Low-Voltage Headphone Amplifier craigtone Swap Meet 3 5th January 2013 02:46 PM
Original A9.8 input voltage modification cicada_17 Digital Source 2 26th November 2006 09:16 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
