Any help?  First attempt at a "hybrid" using depletion MOSFETS
Old 1st August 2020, 06:39 AM   #71
kodabmx is offline kodabmx  Canada
Spreading triode love.
kodabmx's Avatar
Bingo! Thanks for that
If you can't learn to do something well, learn how to enjoy doing it poorly.
Old 1st August 2020, 02:48 PM   #72
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Originally Posted by kodabmx View Post
Out of curiosity, What would be an appropriate inductance if I was to try and choke load it instead?
1mH? Am I close?
Thanks everyone!
I was in the same boat until I realised that a constant current source made from a transistor or two is often a better choice than an inductor (smaller, cheaper, more linear). Nelson Pass has a few CCS suggestions in his papers.
Oh, 1 mH seems like way too low, but I didn't do the math.
Old 1st August 2020, 06:41 PM   #73
kodabmx's Avatar
Ya I'm starting to think a CCS would be easier. I could even use a second pair of the same MOSFETs... 1mH might work for the PS filter though instead of 1R.
Old 1st August 2020, 08:27 PM   #74
tikiroo is offline tikiroo  New Zealand
If the inductance was below the source (see the MoFo thread) you need upwards of 30 mH depending on how low you want to go in frequency. With the inductance above the drain, the impedance is much higher, extremely high in your case as you have no local feedback, and it only becomes practical if you can use a centre-tapped choke (e.g. the primary of a 115+115 power transformer) in balanced mode, where you can get tens or hundreds of Henries.
A CCS works well but you don't get the extra voltage swing and efficiency is still half of an inductor loaded output. That then evolves to a modulated CCS where the sum of the current in the top and bottom halves is kept constant. It is then effectively operating push-pull but without the second harmonic cancellation as the input signal only drives one half. The ALPHA Nirvana on this forum is one example.
Old 3rd August 2020, 10:12 PM   #75
kodabmx's Avatar
Ya?
Today I got finally 120V 300W bulbs. I had to drive over 100 km round trip to get them - Seems Sylvania doesn't sell them in Canada anymore.
The amp is improved with them though.
Next my idea will be to swap the MOSFET and the bulb to make it a source follower. I think that will lower the Zout and the input capacitance, yes?
Old 4th August 2020, 03:10 AM   #76
TonyTecson is offline TonyTecson  Philippines
diyAudio Moderator Emeritus
TonyTecson's Avatar
incandescent lamps are going the way of the dodo bird, same with compact flourescents..
if people react to you a certain way, it is not because of them but more because of you....
  Reply to this post
Any help?  First attempt at a "hybrid" using depletion MOSFETSHide this!Advertise here!
Posted "NuClassD" amp design: 50W hybrid class-D / Korg Nutube pmillett Tubes / Valves 48 15th June 2020 07:06 PM
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets opc Solid State 2634 3rd March 2020 12:44 AM
Using "Drive Voltage" Spec in design with MOSFETs Hearinspace Tubes / Valves 14 1st January 2019 05:33 PM
Use "mu output" from depletion mode MOSFET load? rongon Tubes / Valves 25 29th April 2015 08:16 AM
First DIY attempt: "Gravitas" subwoofer gandalfandula Subwoofers 0 19th January 2015 12:44 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
