So, I found a power amp, specifically this one:
STK4133II WITH BOARD - Integrated Circuit - KSP ELECTRONICS
(Yes, with the board)
I searched the web but didn't found any datasheet that explaines what are those 18 pins do or even better, where shall i connect the 9 coloured cables of this board.
Does anyone have any clue?
I saw this but It's in German (I suppose).
Besides from the different language It doesn't even have the information I need.
At how many volts this amp functions? How many watts output does it have?
From the small research I did, I understood that this datasheet only describes how to replace a power amp from old sony devices.
Correct me if I am wrong.
Edit... just realised this is showing the STK4132, not the 4133
Look here:
STK4132II datasheet(1/8 Pages) SANYO | 2ch AF Power Amplifier (Split Power Supply) 20W + 20 W, THD =1%
20 watt and -/+23 volt recommended supply.
Look here:
This item is totally obsolete and the only information would be to trawl the interweb for a Sony product that uses one and get the values from there.I saw this but It's in German (I suppose).
I am not sure but I will assume that Donberg is wrong. Thanks for the Info!!!
I think so too.
I remember STK voltage regulators from VCR's And they did
not have that many pins, maybe 12.
See example.
That's the one, and I seem to recall a STK5482 as well. A long time ago
- Found a Power amp "STK4133ii"
