MJL1302/3281
MJL1302/3281
Old 19th May 2020, 06:57 PM   #1
ManUtd is offline ManUtd  Norway
ManUtd's Avatar
Default MJL1302/3281
I have a lot of these transistors and want to use them for repairing my ASW-4000 amplifier from B&W.Originally is placed 2SC5200 and 2SA1943.
Can they be just swapped if i also replace drivers for them?
Old 19th May 2020, 07:06 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I suggest to investigate from the very start of the circuit, if there are low signal transistors, resistors and diodes, damaged. Usually those transistors, when blow, kick back trough its base connection, making a cascade of components burned although its appearance is OK.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 19th May 2020, 08:10 PM   #3
bullittstang is offline bullittstang  United States
MJL1302/3281
Yes they can be swapped for the 5200/1943's, but as Osvaldo mentions - make sure the rest of the circuit is working properly, or you will just have more blown transistors.
MJL1302/3281Hide this!Advertise here!
FS: Matched transistors NJW1302/3281 Nicke Swap Meet 0 7th December 2015 09:02 PM
2SC1302 and MJL1302 andrewlebon Solid State 1 19th July 2014 04:54 PM
MJL1302 and MJL3281 best driver transistors AMV8 Solid State 32 31st December 2012 09:14 AM
wanted :MJL1302/3281 flatpack pinkmouse Swap Meet 5 4th December 2006 08:38 AM
Old Toshiba power transistors 1302/3281/554/424 Stuart Easson Swap Meet 1 4th May 2006 08:26 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
