Mark Levinson No23 repair help
Thread Tools
Old 13th January 2021, 07:43 PM   #351
Handel is offline Handel  Netherlands
Originally Posted by Hans Polak View Post
Hi Hannu,
Look here for limiting behaviour at 10KHz.
Hans
Ok. There the current does not drop immediately when hitting to the protection like at low frequency but stays at the same level the whole positive (or negative ) side. Different behavior.
Old 14th January 2021, 08:26 AM   #352
Hans Polak is offline Hans Polak  Netherlands
Yes it does behave the same, see the short spike at the left.
Current goes up, gets interrupted by the protection and goes down.
It goes up again to a stable level when input voltage rises to 3.1V.
The difference with the 800Hz image is that the used input voltage went up to only 70mV.
Hans
Old 15th January 2021, 07:01 PM   #353
That is true. I forgot that you have 3.1V in the input.
I noticed that for some reason in the right amp the output transistors at negative side are not well balanced in idle anymore. One of the voltage over 0.22ohm resistors is 20mV as the others have 9-10mV. Do I kill this transistor if I make the same multimeter test? How is it possible that I have now so different results? I don't think I have made errors in measurements.
Old 15th January 2021, 09:41 PM   #354
It is not an optimal match, but as the current increases the 0.22R resistors will reduce the differences, so donít be afraid this single transistor will be killed while doing the multi meter test.
Hans
  Reply to this post
Mark Levinson No23 repair helpHide this!Advertise here!
Thread Tools
need some help on my Mark Levinson No23 loveaudio Solid State 9 31st March 2020 09:53 PM
Mark Levinson No. 39 DAC repair astouffer Digital Line Level 11 13th January 2020 06:25 PM
Please help on Mark Levinson No 331 amp repair birdyman Solid State 5 21st July 2013 04:04 PM
Mark Levinson ML3 or No23 ???? deafbykhorns Solid State 3 6th June 2011 11:15 PM
Levinson No23 DC offset troubleshooting deafbykhorns Solid State 7 1st November 2006 01:44 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
