JFET-only Circlotrons without negative feedback.
Old 26th March 2020, 01:36 PM   #31
UltimateX86 is offline UltimateX86  France
only 630PF !!
I do not sell anything, I'm just trying to build a www.circlotron.audio
Old 26th March 2020, 02:10 PM   #32
Yurik_V is offline Yurik_V  Ukraine
Originally Posted by padamiecki View Post
is there a difference in sound Sic vs IRFP?
IRFP150 only
Old 26th March 2020, 03:01 PM   #33
Originally Posted by Svjatoslav View Post
Version for silicon carbides JFET.
In all versions, it is important to check the initial current of the VT1-12 transistors.
Because according to the old passport data, the characteristics are not what those of modern manufacturers.
The version is designed for layout. Because I'm still unfamiliar with powerful SI-C JFET
hi and thanks
where do you found genuine 2sj103 and 2sk246 ?
I have some Y and GR but not BL
Old 26th March 2020, 03:31 PM   #34
I bought about 10 years ago in Belarus. )
e-bay you can buy pairs J103/K246.
Old 26th March 2020, 04:03 PM   #35
jpatay is offline jpatay  Ukraine
VT5, VT6 must have a leakage current: 8-10 mA. Then the voltage at the drain- source VT3, VT4 will be 3-3.2 V.
2SJ103BL: 6-14 mA.
Old 26th March 2020, 07:02 PM   #36
Svjatoslav is offline Svjatoslav  Ukraine
hi and thanks
Long time ago purchased. For the "Breeze" Amplifier.
Breeze amplifier.
BF245 tried, but didn't like it. Because they were burned out.
JFET-only Circlotrons without negative feedback.Hide this!Advertise here!
Negative Feedback Amplifier with embedded Positive Feedback Booster Koonw Tubes / Valves 57 24th June 2015 08:05 PM
How the negative feedback really works and an alternative feedback question Amit_112dB Solid State 37 21st April 2014 03:16 PM
negative feedback dscottguitars Instruments and Amps 7 13th September 2011 04:43 PM
Negative Feedback AmpBuilder225 Tubes / Valves 7 20th February 2009 08:05 PM
Get away from negative feedback ? N-Well Pass Labs 3 1st March 2006 10:17 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
