JFET-only Circlotrons without negative feedback.
Thread Tools
Old 7th April 2021, 02:03 PM   #291
alexopth1512 is offline alexopth1512
Hello for stereo setup, two channels.
for the non high power rails, we can use the same PCB with common supply? I.e. connect both channels to same supply board?
We can do the same for the high power rails for each channel, or we have to have 4 separate rails for high power?
Old 7th April 2021, 02:12 PM   #292
jpatay is offline jpatay  Ukraine
The stabilized power supply can be one for two channels.
But it is better to have a separate stabilized power supply for each channel. Then there will be no background at all.
Yes, the output stages require 4 separate power supplies. One power supply is designed for one powerful transistor.
Old 7th April 2021, 02:21 PM   #293
For the output stage Mosfet:
Old 7th April 2021, 03:02 PM   #294
gaborbela is offline gaborbela  Canada
Interesting, great project, I want to follow.. Maybe build something.
Old 7th April 2021, 03:04 PM   #295
It would be very good.
Old 7th April 2021, 07:28 PM   #296
Interesting. No stabilization eh? Only one capacitor? No humming, buzzing or something?
By the way, if we have small differences in voltage, wouldn't mean that some (minor) current would flow between the output FETs? Have you measured that?
I have received all JFETs. I have also designed a new PCB and a new stabilized PSU PCB (I like to build my own PCBs). PCB for amplifier has arrived, PCB for PSU will be ordered.
I am now wondering about the output stage. I have already a high power stabilized PSU (more than 10A) from another project and works great. But it will be huge to build it 4 times. I may try something in the middle, I ll design something.
Old 8th April 2021, 05:09 AM   #297
No need for stabilization output stage. There is also stabilization of the preliminary stage.
No noise is heard in the speakers. If you are using one power supply for the two pre-channels, then a slight buzzing sound may be generated.
The difference in the voltage value of the output stage is permissible, but if the voltage is high, then the Mosfets will heat up more.
One diode bridge needs 10,000 uF. I am waiting for the result of the amplifier assembly. Write about your work results.
Old 8th April 2021, 07:51 AM   #298
Output stage on P-channel Mosfet. (Example).
  Reply to this post
JFET-only Circlotrons without negative feedback.Hide this!Advertise here!
Thread Tools
Negative Feedback Amplifier with embedded Positive Feedback Booster Koonw Tubes / Valves 57 24th June 2015 08:05 PM
How the negative feedback really works and an alternative feedback question Amit_112dB Solid State 37 21st April 2014 03:16 PM
negative feedback dscottguitars Instruments and Amps 7 13th September 2011 04:43 PM
Negative Feedback AmpBuilder225 Tubes / Valves 7 20th February 2009 08:05 PM
Get away from negative feedback ? N-Well Pass Labs 3 1st March 2006 10:17 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
