Relay timing
Relay timing
Old Yesterday, 02:35 PM   #71
Max Martin is offline Max Martin  Sweden
Max Martin's Avatar
Yes!
just do it.
Old Yesterday, 05:57 PM   #72
Mooly's Avatar
Relay timing
Good
So next step is to see exactly what the speaker relays are doing.
If you connect your meter across diode D713 (that is the diode across the relay coils) we can look at the voltage and get an idea of what is going on.
(There might be some other small signal muting of the audio buried within the circuit but lets get the basics sorted first)
So as you power the amp up I would expect to see the voltage across the relay coils come up to say 25 to 30 volts or so after a delay of 2 to 3 seconds.
Exact voltage depends on the resistance of the coils and the current they draw which in turn will cause a volt drop across R766. The relay voltage may well be marked on the relay itself.
So get an idea of the voltage and the time delay and then try switching off and on and see what the delay in coil voltage appearing is then. I would expect it to be a constant delay but lets see and put some numbers in.
Old Yesterday, 07:47 PM   #73
Max Martin's Avatar
The old relays had a res of 3.2k while the new ones are 2.4k. Voltage of relays are 36v it says (2x Omron Gr2-1Ae 36vdc)
Originals was chinese and one of them worked poorly.
First things i threw in and it worked good so i didn’t bother to adjust anything. Voltage i measured before. Relays see 32.75v i think
Will check voltade over that D713 too. But i don’t have 2-3 sec delay?��
just do it.
Old Today, 08:06 AM   #74
Mooly's Avatar
Relay timing
The relays should see around 28 volts (very approx) if they have 2k4 coils and the main supply is +34V. The 6 volt drop is down to the relay current causing a drop across the 220 ohm limiter resistor R766.
Anyhow... just like with pin 6 we need to be 100% sure what is happening and that means measuring the coil voltage and in particular looking at the delay you see.
There a couple of possibilities for the way all this works and so we need measurements to clarify how it all operates as one unit.
1/ When you power up from a cold start (all off, everything discharged) what delay do see by measuring the voltage across the relay coils?
2/ If you remove power (unplug from mains) for a few seconds and then repeat the above step what delay do you now see?
What we are going to look at here (if there is a difference) is what has changed around the module. The delay should be repeatable.
Now look at the circuit and find D701 which is across the power standby relay coil.
When you initially plug the unit in to the mains does this coil get 5V across it or does it not energise until you take it out of standby.
What we are trying to determine here is whether the standby function switches this relay on and off correctly and how that relates to the modules delay time. The module is fed from a 34V rail that is derived from a supply off the large transformer and so the module should give a repeatable delay each time the power relay is cycled on and off.
(a random thought... is it possible you blobbed any solder onto the module during the recap?)
Relay timingHide this!Advertise here!
Is timing important for crossover distortion? Elvee Everything Else 40 8th December 2014 02:52 PM
Tube Plate Voltage Timing perpi Tubes / Valves 88 17th September 2013 02:03 PM
Off-receiver; subwoofer timing control options Ektalog Subwoofers 0 24th February 2010 05:44 AM
Thread Posting and Timing Out and losing the POST KP11520 Everything Else 7 9th November 2007 02:36 PM
WIKI timing out? tiroth Forum Problems 8 19th April 2004 10:47 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
