Hifi amp signal flow question
Hifi amp signal flow question Please consider donating to help us continue to serve you.
Old 17th January 2020, 02:37 AM   #31
Divad123 is offline Divad123
Rayma - fantastic, I'll do close inspection of solder connection and tracks. I'll make a list and order the resisters and capacitors although I do have a wee stock of both but not the emitter resisters, I'll definitely have to order them.
I'll keep you posted. Should only take a few days for delivery if I order the parts tomorrow. Thank you.
Rick, thanks for the information - I'll try that when I have problems with my next project and need advice. Note - I said 'when' I have problems, not 'if' lol.
Old 17th January 2020, 03:53 PM   #32
Sorry Rayma - before I order - the emitter resistors, is there any physical difference between them and normal resistors. The ones on the Rotel look like normal resistors with the coloured value rings but a bit larger than the other resisters on the PCB.
It's just in case I recive ordinary resistors, albeit of the required value, when I should have ordered proper 'emitter' ones.
Thank you sir
Old 17th January 2020, 04:24 PM   #33
rayma is offline rayma  United States
Usually they are wire wound but can be metal oxide, etc. Can you post close photos of them?
Old 17th January 2020, 04:42 PM   #34
Default Photos of Left and right Emitter Resistors
HI Rayma,
I used Rick PA Stadel's method for uploading pics, hope it works here goes -
Old 17th January 2020, 04:54 PM   #35
HI Rayma,
Those are metal oxide types. Get a wattage that is the same or larger physical size.
Old 17th January 2020, 05:46 PM   #36
Thanks Rayma,
Will order this evening.
Cheers
Old 17th January 2020, 05:48 PM   #37
Those are likely to be 2W or 3W resistors, order the same physical size or larger.
Old 17th January 2020, 08:21 PM   #38
Will do Rayma - thanks for the help with the resistor question. Will get back to you shortly
Cheers
Hifi amp signal flow questionHide this!Advertise here!
Question does the DC in a hifi have AC in to carry the sound signal ? Divad123 Solid State 35 29th December 2019 09:00 AM
Possibly stupid question regarding current flow bogdan2011 Everything Else 15 6th July 2016 10:36 PM
Basic question about electron flow to tube grid Planobilly Instruments and Amps 11 23rd June 2016 11:19 AM
Signal-Flow (Box) Diagram of Shadow Hills Mastering Compressor TheeAldeen Solid State 1 10th January 2015 01:39 AM
Wave/Pressure Flow question johninCR Multi-Way 1 10th October 2006 08:53 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
