Harman Kardon Citation 11 preamp EQ board question
Old 16th January 2020, 12:49 AM   #11
erniegiro is offline erniegiro
Default Confirmed 1 H inductor is bad
Originally Posted by djoffe View Post
I'm still a little confused...what is the "bad" inductor resistance with one (or both) ends lifted out of the circuit?
If it's infinite...then there's an open...and it must be replaced.
If it's much less than 400 Ohms, then there are shorted turns, and it must be replaced.
Finally...you could determine if it's the only problem by swapping the good inductor to the bad side.
Once we know for sure about the status of the inductor, we can go about finding or making a replacement.
Dan, I did as you suggested and swapped the good inductor to the bad side. The bad side now works.
I imagine this means I have a bad inductor, and like you explain it would have to be replaced or built.
I have found a 900 millihenry inductor at Mouser, it's called a telecoil, meant for use in hearing aids. It's Knowles part 5100-253444. These are in stock.
I attach the pdf. It's small appx. 9mm X 2.3mm, 15% tolerance. It's the closest I have found anywhere to the 1 H value.
Knowles also makes a 520 millihenry inductor, also 15% tolerance, part 5100-253144. I attach the spec sheet for it too.I am wondering whether 2 wired in series would achieve 1.04 H, closer to the original HK spec.
However I am not sure how suitable either part would be as a replacement for the original part.
Maybe you can give me your thoughts, and advise how to proceed.
File Type: pdf Knowles 5100-253444 900 mH inductor.pdf (60.6 KB, 3 views)
Old 16th January 2020, 01:16 AM   #12
djoffe is offline djoffe  United States
Good searching, but the DC resistance of both inductors looks kind of high...I don't think they are good replacements.
Your existing inductor must have a shorted turn or turns, thus the low DCR.
I'm doing a little looking around...I may have an answer for you tomorrow, with a bit of luck. If no luck, we might be able to do an active inductor as a replacement.
www.akitika.com Featuring the GT-102 Power Amp and PR-101 Preamp kits
www.updatemydynaco.com Featuring upgrades for classic Dynaco Solid State Equipment
Old 16th January 2020, 02:00 AM   #13
Dan, thanks again for your help. I look forward to what you think may work.
Ernie
Harman Kardon Citation 11 preamp EQ board questionHide this!Advertise here!
Harman kardon citation 7.1 mjstriker5 Solid State 8 25th May 2017 04:17 AM
WTB Harman Kardon Citation II chicofi Swap Meet 7 21st February 2016 11:57 PM
New Harman Kardon Citation II bigbargain Tubes / Valves 34 21st January 2014 05:18 PM
Harman Kardon Citation II PI question Printer2 Tubes / Valves 37 3rd January 2011 06:40 PM
Harman Kardon Citation 16 Tom469 Solid State 5 2nd February 2008 02:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
