Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Solid State Talk all about solid state amplification. |
i think most of us familiar with L10 amplifier see also schematic on picture
I have one application that I have primary rails of regulated supply to feed the first stages lets say up to the drivers and a lower rail very beefy to feed the output Can one quick simulate for what is the maximum voltage to feed the input stage ?
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#2 |
Ironically, this one cannot be determined by simulation (which rarely represents breakdown voltage accurately) but requires old-fashioned studying of datasheets instead. I think the 2SD667/2SB647 are the bottleneck, being Vceo = 80 V parts and having to swing almost rail to rail. So roughly +/- 40 V max, or +/-50 for 667A/647A. In the latter case a fault condition with the output pulled to V+ may still destroy Q6 (a 65 V part) and/or C4.
#3 |
Vceo max. may vary between manufacturers. Some examples of 2SD667A/B647A appear to use the same die as 2SD669A/2SB649A (as for example, do BD139/BC639). http://www.secosgmbh.com/datasheet/p...OD/2SD667A.pdf
There are even standard T092 versions of 2SD669/B649 to add to the confusion. Even with datasheets, I would test the breakdown voltage before fitting.
If only I had listened.... Last edited by Ian Finch; 19th November 2019 at 11:34 PM. |
Thread | Thread Starter | Forum | Replies | Last Post |
Quick 'n dirty sub simulation? | head_unit | Subwoofers | 2 | 30th January 2012 12:34 AM |
IV Simulation Question | PigletsDad | Digital Source | 1 | 7th April 2008 01:41 PM |
Quick quick question ! | guitvinny | Pass Labs | 6 | 7th February 2007 05:20 PM |
simulation question | schiller | Multi-Way | 13 | 6th September 2006 10:22 AM |
New To Site? | Need Help? |
