NAD C375 integrated amplifier, better sound changing some comp..?
NAD C375 integrated amplifier, better sound changing some comp..? Please consider donating to help us continue to serve you.
Old 2nd December 2019, 11:13 PM   #11
Max Martin is offline Max Martin  Sweden
Max Martin's Avatar
There is a 10uf electrolytic (301/401) in the signalpath, and a few ceramic caps that could be replaced to Wima FKP for example. I would recommed to replace all caps. My 2200uf/ 50V was leaking.
Like sgrossklass said they're totally let doen by bad parts and mostly here its the caps.. JH (jinghai?) and the are BAD.
Also replace the 4x2.2K (3W) res to 5w, they run insanely hot! Also down by the 18v reg there is 2x200R that could be 3w instead of 1W.
Have you checked all voltages? 18, 64 and 68 if i remember right
Anyway this amp was manufactured from 2003 to 2008. The C275 came after that.
Hangaard; You have PM
just do it.
Old 2nd December 2019, 11:15 PM   #12
Max Martin's Avatar
Btw, i think this amps sounds far from sharp, with my Be tweeters it is very sweet and warm treble.
just do it.
Old 3rd December 2019, 05:13 PM   #13
Max Martin's Avatar
Well, see now this was about c375, not c372/272. Sorry
just do it.
NAD C375 integrated amplifier, better sound changing some comp..?Hide this!Advertise here!
18 Sound NSD1095N Comp Drivers & XT1086 Horns fatmarley Swap Meet 5 30th May 2018 07:55 AM
How does changing coil DCR affect sound? cyto Full Range 1 4th April 2012 12:10 AM
Rotel Integrated Amplifier one cahnnel out No sound mrfix90 Chip Amps 4 26th August 2009 04:26 AM
changing an integrated tube amp to a power amp f1802llk Tubes / Valves 8 10th October 2008 06:25 PM
Bell Sound Mono Integrated Amplifier Dr. Photon Tubes / Valves 2 15th July 2005 03:35 PM
Copyright ©1999-2019 diyAudio
