Alpha Nirvana 39w 8ohm Class A Amp
Old 16th November 2019, 08:27 AM   #151
EmeryBB is offline EmeryBB  Australia
Thanks mate.
Old 16th November 2019, 10:38 AM   #152
jacques antoine is offline jacques antoine  France
Originally Posted by xrk971 View Post
1.2A x 40V would be 50W. A manageable amount of heat for a small CPU cooler or a 4U x 300mm heatsink, maybe even 3U.
Downsizing to 50W dissipation to fit in a fanless 3U chassis would definitely get the best of both worlds.
Old 16th November 2019, 01:20 PM   #153
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
That’s 50w per channel.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 16th November 2019, 01:31 PM   #154
Cambe is offline Cambe
Great work here. Just wondering if this amplifier might be a good fit with a pair of Delaware DM947 Monoliths?
Old 16th November 2019, 02:18 PM   #155
daanve is offline daanve  Netherlands
That would be very comparable with USSA-5.
Different schematics, but though I have Exicons as well as selected IRPF pairs, I tend to prefer the "audio" lateral power mosfets.
Old 16th November 2019, 03:19 PM   #156
Thatís 50w per channel.
Abslolutely, could each of the two Hifi2000 3U 40x300mm heatsinks dissipate ~50W for a stereo set?
Old 16th November 2019, 08:22 PM   #157
Got Foam?
xrk971's Avatar
Yes, I think the 3Ux300mm heatsinks can handle 50w each no-problem.
Old Today, 12:08 AM   #158
Got Foam?
xrk971's Avatar
The prototype PCBs arrived. 1.6mm but 2oz copper. If this works, production will be 2mm, 2oz, and ENIG with blue solder mask.
Boards look nice. Very compact layout thanks to JPS64!
File Type: jpeg 0B1B27AA-1350-49E2-A594-304E256B0462.jpeg (864.7 KB, 25 views)
Old Today, 12:42 AM   #159
zman01 is offline zman01  Bangladesh
X,
Good to know that PCBs have reached you - now look forward to your verification build.
Alpha Nirvana 39w 8ohm Class A AmpHide this!Advertise here!
The Alpha Big Boy with Buttah (ABBB) 52w Class A Amp GB xrk971 Group Buys 287 Yesterday 02:46 PM
63watt class A into 8Ohm, 110watt semi-class A into 8Ohm, @ 20Khz 3rd harmonic -90dB FdW Solid State 51 8th November 2019 12:30 PM
200W @ 8OHM Class D HiFi Stereo Amp sssuneth Class D 1 27th January 2012 10:23 PM
8ohm resistor in series with 8ohm speakers for a 16ohm OT? Reidy- Tubes / Valves 8 11th January 2010 12:25 AM
Small Class-D chip wanted. ~25W/8Ohm rkn Class D 7 12th March 2009 02:44 AM
Copyright ©1999-2019 diyAudio
