Alpha Nirvana 39w 8ohm Class A Amp
Thread Tools
Old 26th October 2020, 08:27 PM   #1461
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
As far as I can tell, the OPA1656 is only available as SOT8 SMT. But they have DIP8 adapter boards for them so you can pop them in a socket meant for swapping opamps. Otherwise it will require desoldering and resoldering. Not terribly hard with SOT8. I have 4 of them on the BTSB designed by Jhofland and just really like how neutral and great sounding they are.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 26th October 2020, 09:24 PM   #1462
karucho is offline karucho  Europe
Default OPA1656
Hi xrk971,
Beautiful plate...Thank you for your feedback and advice on availability and package size.
Greetings
Old 23rd November 2020, 08:50 PM   #1463
GnuB is offline GnuB  United States
GnuB's Avatar
X, there's also a group buy being put together for a 4Ux500mm heatsink chassis; plenty of room:
Ultimate 4U 500mm Chassis - Who is interested?
"Just been speaking with Gianluca (Modushop) about doing a 4U 500mm Chassis.
Please let me know who might be interested and we can get this show on the road.
For 10 it will be 310 Euro
For 25 it will be 250 Euro"
Originally Posted by xrk971 View Post
Some possible cases for the Alpha Nirvana that look like a good value. You will have to d0 your homework to make sure the dimensions are big enough to hold your amp, trafo(s), PSU, etc. Also, check to see if the heatsink is big enough based on general dimensions. For reference, I am running 4U x 300mm x 25mm fins on each channel and it runs about 47C to 50C.
  Reply to this post
Alpha Nirvana 39w 8ohm Class A AmpHide this!Advertise here!
Thread Tools
The Alpha Big Boy with Buttah (ABBB) 52w Class A Amp GB xrk971 Group Buys 409 25th November 2020 12:06 AM
63watt class A into 8Ohm, 110watt semi-class A into 8Ohm, @ 20Khz 3rd harmonic -90dB FdW Solid State 51 8th November 2019 12:30 PM
200W @ 8OHM Class D HiFi Stereo Amp sssuneth Class D 1 27th January 2012 10:23 PM
8ohm resistor in series with 8ohm speakers for a 16ohm OT? Reidy- Tubes / Valves 8 11th January 2010 12:25 AM
Small Class-D chip wanted. ~25W/8Ohm rkn Class D 7 12th March 2009 02:44 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
