Electro Research Corp. Model A 75 Iverson power amplifier.
Old 21st October 2019, 06:39 PM   #1
as_audio is offline as_audio
Default Electro Research Corp. Model A 75 Iverson power amplifier.
Last week in my workshop : the "legendary" Iverson Power Amplifier.
Pictures of front and backside. The original time counter has been replaced
by one made in Germany and has already counted more than 8000 hours.
Speaker posts and RCA sockets are not original.
Old 21st October 2019, 06:42 PM   #2
ubergeeknz is offline ubergeeknz  New Zealand
That is one industrial looking piece of gear
Old 21st October 2019, 06:47 PM   #3
Default More pictures
Top and bottom cover can be removed for full access to the self supporting chassis.
The main caps are not original. Somebody added a supply and regulator for the fan.
Mains transformer has a primitive EI core. Driver board in front is separated from the
current amps on the heatsinks. The big caps seem to be assigned l and r, but share
the same rectifier.
Old 21st October 2019, 06:49 PM   #4
Default manual
This attachment was called a manual. Simple version is : to start the amp push "Power" and then "Reset".
Old 21st October 2019, 06:52 PM   #5
Default schematic diagram
This bad copy is supposed to be an original schematic.
I do not have a better version and can not tell it is complete or correct.
Old 21st October 2019, 06:55 PM   #6
Default schematic with mods
Here the diagram of a single channel with changes and modifications made by
Russ Sherwood of EKSC Eagle, eagle audio .
The amplifier in question apparently has these modifications.
Old 21st October 2019, 06:57 PM   #7
Default Conversion to European Mains Voltage
The transformer has two primaries which can be wired in parallel for 120 and series for 240 volts ac.
Old 22nd October 2019, 01:23 AM   #8
dexter is offline dexter
PSU transformers: EI vs. toroidal, and more – Audial
Old 22nd October 2019, 01:53 PM   #9
tubesguy is offline tubesguy  United States
That's one reason that I really, really wanted one back in the day.
Old 22nd October 2019, 02:27 PM   #10
Mark Tillotson is offline Mark Tillotson
I would suggest adding a SpeakON jack if there's room.
Electro Research Corp. Model A 75 Iverson power amplifier.Hide this!Advertise here!
Roger Grodinsky Research Model Five High current amplifier info 2chanman Solid State 4 15th July 2019 09:35 PM
Audio Research D51 tube power amplifier rayma Swap Meet 7 4th November 2015 09:02 PM
Big Electro Research Class A amp lgreen Solid State 8 9th August 2010 08:35 PM
Class D audio power amplifier research rob mullen Class D 31 15th November 2008 10:30 PM
ANA Audio Research APA 8 Power Amplifier. Heard of it? Junior Solid State 0 1st August 2007 01:56 AM
Copyright ©1999-2019 diyAudio
