Opamp pyramid stacking for higher voltage operation
Old 21st October 2019, 09:15 PM   #11
Mark Tillotson is offline Mark Tillotson
Of course an input opamp is needed if a gain more than 3 is wanted, but the output swing is about 90V p2p. Click the image to open in full size.
Note the opamp's rails swing well above and below ground as they track the output, but the input voltages should just stay within limits - a protection resistor and clamps on the non-inverting input would be a wise precaution.
This circuit could drive a similar circuit using the LTC6090 to triple the swing again (LTC6090 swing is 140V), so upto 270V swing would be possible.
Old 21st October 2019, 09:35 PM   #12
stocktrader200 is offline stocktrader200  Canada
hows the performance, especially when clipping
Old 21st October 2019, 09:45 PM   #13
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by Mark Tillotson View Post
I've realized the transistor bootstrapping circuit of Surjan Dogran's can go up to a tripling of output voltage swing if the gain is set to 3, non-inverting. This version uses 50V rails, runs an opamp at +/-18V (limited by a zener for protection) and has the bootstrapping split into a DC and AC path to allow the bootstrap factor to set optimally even though the rail voltage isn't 3 times 18V.
Well, in the end, there seems to be a consensus on the practicality and convenience of bootstrapped rails:
EZ-Dump: dump your current without really trying
But of course, this does not detract from the merit due to the pyramidal scheme, which is compatible with the bootstrap, in case the swing available is not sufficient.
I happily welcome any new and creative approach, and the pyramid certainly counts as such
. .Circlophone your life !!!! . . ♫♪ My little cheap CirclophoneŠ ♫♪
Electrify your daily life!!! ....⚡⚡ ELEKTRIA ⚡⚡
Old 21st October 2019, 10:41 PM   #14
Click the image to open in full size.Click the image to open in full size.
Seems OK, if the emulation is good. I added 1k input resistor to the non-inverting input. In practice it won't clip much as the opamp driving it will clip anyway.
Old 21st October 2019, 10:42 PM   #15
Thanks, it was quite pleasing to figure it out - actual breadboarding it might not happen for a while as I mainly have SMT dual opamps at hand...
[ The tripler circuit may get breadboarded soon, though, I have a +/-48V supply. ]
Old 22nd October 2019, 04:53 AM   #16
Iain McNeill is offline Iain McNeill  United Kingdom
diyAudio Moderator Emeritus
Iain McNeill's Avatar
I built some systems using Doug Self's Class G topology which has similarities. I never could get it to sound better than his blameless class B. So forgive me if I smell a free lunch here.
I'd check a few things before building.
PSRR - what does output look like if you put 1uV signal into either supply line.
real load - what happens if you add a bit of parallel C or series L in that 2K load resistors.
Op-amp supply voltage - in-circuit, worst case load, related to PSRR but any datasheet violations?
there's a lot of complexity with this solution so expect unforeseen interactions.
Old 22nd October 2019, 11:54 PM   #17
Opamp circuits aren't very sensitive to rail noise, I sometimes test simulations by injecting 1V tones into the rails and see how much they bleed into the output or intermodulate the output.
BTW are you talking about the pyramid driving an OS - I presume so due to the complex load question - I'm not advocating any particular OS, that's just the motivation for the topology.
The tripler is just part of a VAS stage so its load would be the drivers or pre-drivers.
And I've tested the tripler using +/-45V rails and an LT1113 I had knocking about. Seems to work stably and was getting 80V p2p out into 10k load. I used KSA992/KSC1845's as the bootstrap transistors so they were running a little hot, didn't want to drive a heavy load.
I realized the zener that protects the opamp from over-voltage can lead to heavy current draw through the transistors if the biasing network isn't setup correctly for the supply voltage - it might need a bit of rethinking.
Old 23rd October 2019, 03:02 AM   #18
hitsware is offline hitsware
Simpler approach :
https://www.analog.com/media/en/tech.../ADA4700-1.pdf
Better yet :
https://www.analog.com/media/en/tech...ets/6090fe.pdf
Old 23rd October 2019, 03:46 AM   #19
Yes, driving an OS as in your schematics above, in turn driving a real speaker with challenging crossover.
Good point about the bootstrap transistors, they're dissipating almost 0.5W each quiescent. Driving the drivers will increase this dissipation.
Is there any way the V+ supply to op-amp could be less than the in/out voltage (vice versa for V- rail)?
A square wave test would be revealing.
There's so much more to consider with a complex design like this and I can't convince myself on first view that this is unconditionally stable. Personally, I've lost many battles to a simple cascode VAS as demonstrated by Self et al. so I appreciate what you're trying to do here.
sorry to drag the meal metaphor along, but the proof of the pudding....
Look forward to hearing more.
Old 23rd October 2019, 04:53 AM   #20
Opamp pyramid stacking for higher voltage operationHide this!Advertise here!
EL84 higher voltage operation Skorpio Tubes / Valves 15 13th June 2018 10:38 PM
Using multiple voltage transformer to get higher voltage hondatech739 Power Supplies 20 1st February 2013 02:04 AM
Even Higher Voltage Discrete OPAMP Application nerdman Solid State 0 17th January 2012 04:42 AM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 05:01 AM
Copyright ©1999-2019 diyAudio
