Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Solid State Talk all about solid state amplification. |
Thread Tools |
#271 |
I guess you meant R12a / R14a ?
https://www.diyaudio.com/forums/atta...s-img_2305-jpg They are there to allow you to fine trim dynamic current ratio. UDNeSS, or You don't need Semisouth's The values provided in the schematics are based on the FQA FETs used by Morde. You can change the current ratio by changing the ratio of R11//12 and R13//14. Best to play with it in Spice first to get an idea. Patrick
xen-audio.com |
#272 |
Thanks Patrick.
I thought that was the case based on the table you added to the PDF. I was just surprised to see that R11a is listed in the BOM and based on the schematic it is in parallel to R11 ![]() ![]() Seems I cannot load images from my phone, will just leave it out and see if i need to trim. I used the same FETS as Morde so let's hope it all works without additional tweaking. ..dB Last edited by dBel84; 29th November 2020 at 08:48 PM. |
#273 |
R11a in the schematics = R12a on the PCB.
I did not have space to place it under R11. And was too lazy to change document. ![]() Patrick
xen-audio.com |
#274 |
![]() I would never call you lazy, appreciate all the selfless work you do for our amusement ![]() |
#275 |
#276 |
If that trimmer is parallel to R11,12,13, or 14 then it will not survive for long.
The easiest way to trim bias is to adjust R6. R12a, 14a should be used to adjust current ratio. And they want to be 0.4W minimum. See Appendix 2.1 of post #89. Patrick
xen-audio.com |
#277 |
Hi. Yes, trimmer is parallel to R6. Allows adjustment from 150 to zero ohm.
#278 |
So you drilled through the PCB to install the trimmer for R6.
I strongly suggest you to replace it later with fixed resistors after trimming. The power resistors next to it will get hot. And trimmers will drift with temperature, even if they survive the heat. Patrick
xen-audio.com |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
WTB Semisouth SIT Pairs | Doppler9000 | Swap Meet | 0 | 26th December 2017 09:34 PM |
Semisouth goes Dodo ; what now ? | Zen Mod | Pass Labs | 271 | 18th October 2017 05:47 PM |
FS: 4 off SemiSouth SJEP120R063 NOS | bommels | Swap Meet | 2 | 13th October 2016 11:53 AM |
WTB: Semisouth SJEP120R100 | ljfont | Swap Meet | 2 | 10th September 2015 02:32 AM |
semisouth sjep120r100a | yero | Solid State | 1 | 15th June 2012 11:02 PM |
New To Site? | Need Help? |
