Amp for sub...Recommendations
Old 23rd September 2019, 10:23 AM   #1
ubergeeknz is offline ubergeeknz  New Zealand
Default Amp for sub...Recommendations
So I've acquired an old JBL Digital 12 sub which has a built in amp. The amp is dead. The driver is good. The amp uses a module S53AMI which I'm pretty sure is blown (it's been removed from the main board) - The rest of the board seems okay.
So what I have is a +-42vdc supply, all the necessary filters, and a 4 ohm driver. There's also +5v and +-15v on the board. The transformer seems to have a good heft to it. I would guess 150 or 200VA at least. What's a good amp to build, or module, to fit here? Or is it possible, and worthwhile, to repair these modules? Recommendations please!
Old 23rd September 2019, 10:28 AM   #2
Fenalaar is offline Fenalaar  Norway
A Hypex UCD180 module would be usable here, as long as you have +-42V. It runs on voltages from 30 to 49 volts.
DIYclassd.com
You'll need a spot of free space of 65x25mm on the rear plate to attach the heatsink, though.
Johan-Kr
Old 23rd September 2019, 10:37 AM   #3
The hypex looks ideal! I would love an option at around half that price, but I'm probably dreaming Amp for sub...Recommendations we shall see
BTW. It's a ported box. So a bit of airflow/cooling shouldn't be an issue.
Old 23rd September 2019, 11:12 AM   #4
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
When R9 goes open circuit the amplifier output section stops working as there is no 6volt supply to the FM modulator.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 23rd September 2019, 11:19 AM   #5
I'm guessing wrong thread?
Old 23rd September 2019, 11:26 AM   #6
The amp uses a module S53AMI that module uses a feed from the power to set up the FM oscillator.
This is a JBL Digi 12. See service manual.
Old 23rd September 2019, 11:39 AM   #7
I see! I could always check if that's the issue and not the module... I can see a cap blown across the output, so it got abused at some stage. Worth a try. Thanks.
Old 23rd September 2019, 11:50 AM   #8
My pleasure, let's hope it isn't terminal.
Old 24th September 2019, 09:28 AM   #9
Suffice to say, genius advice.
R9 was very high (and no wonder the heat which it puts out, I replaced it with 2 x 1k 2W in series and they still stunk for a while) and R46 low (5 ohm instead of 47) so I replaced both, put the module back in and low and behold... Life!
Unfortunately there is something oscillating in the input stage, putting a high frequency square wave to the input. There's also a square wave on the output, so the amp seems to work... Already checked all resistors around the opamps, and they seem okay. I've run out of time for tonight ... Any ideas on what might be worth a check, would be most welcome.
Attachment 783223
Old 24th September 2019, 09:40 AM   #10
tmuikku is offline tmuikku  Finland
Send a message via ICQ to tmuikku
My old prosumer mixing console oscillated badly on the EQ section every once in a while. Some of the poti were losing contact turning the filter circuit into an oscillator. Not sure if this could be the case here. Anyway, extruding poti will take a hit sooner or later
Amp for sub...RecommendationsHide this!Advertise here!
845 SET amp recommendations kinku Tubes / Valves 79 1st February 2019 10:04 AM
CD recommendations royd55 Tubelab 2 28th July 2014 01:41 PM
HT Sub Recommendations Lonely Raven Subwoofers 4 25th June 2013 03:18 AM
Kit Recommendations? bassnkeys Solid State 0 17th July 2011 06:11 AM
Copyright ©1999-2019 diyAudio
