Adcom GFA-555 II Amp Oscillating
Old 20th September 2019, 02:45 AM   #1
gdnichols31 is offline gdnichols31
Default Adcom GFA-555 II Amp Oscillating
Bought a defective GFA-555 II off EBAY. Right Channel was good, Left channel was dead and the instan. Distortion LED was on.
I replaced Q107 & Q108 and the left channel came back to life.
I replaced all the elec caps.
I biased both channels and they came in right at 1mV.
Output DC offset is less than 1 mV on each channel.
When I tested the amp in bridged mode, 1 kHz signal into an 8 ohm load, when the output was at about 150 watts, it went into oscillation and blew a fuse.
It's done that twice now.
When I replaced the fuse and test again in Stereo everything is fine.
Any ideas what I should check/look at? I'm guessing a cap somewhere but not sure.
Thanks for the help,
Gary
Old 20th September 2019, 03:58 PM   #2
PB2 is online now PB2  United States
PB2's Avatar
I'd suggest that you put 4 ohm loads on it in stereo and bring up the power to
see if it does the same thing. Output transistor parameters change most dramatically
with current/voltage changes and if they were replaced then it might not be stable.
Old 21st September 2019, 03:47 AM   #3
Default My face is RED
I figured it out not long after I posted the question.
I remembered I still had my scope connected to the output, shorting one side to ground!
I'm lucky the fuse is all that blew.
Once I un-grounded the output it worked great!
Imagine that,
Thanks,
Gary
Old 21st September 2019, 04:18 AM   #4
Phloodpants is offline Phloodpants
Were you testing the amp with a signal generator with a grounded plug? If so, you might have sent a current through the patch cable from the signal generator. The GFA-555 II has a 100R buffer resistor between each channel's signal ground and amp ground. Check resistance between your amp's RCA shields and speaker ground. You might have popped those resistors. It's a metal-oxide type if you need to replace it. (Metal oxide for its high frequency performance.)
http://hoppesbrain.com
Old 21st September 2019, 06:24 PM   #5
Pretty sure my signal generator is isolated but I'll check it and the resistors.
Thanks for the tip.
Gary
Adcom GFA-555 II Amp OscillatingHide this!Advertise here!
Difference between self oscillating and non-self oscillating D-amp. sildex Class D 36 4th August 2010 04:30 PM
Self Oscillating (Oscillating Calculations) Help! Reactance Class D 7 12th March 2010 08:37 PM
Self oscillating fun Eva Class D 92 17th November 2008 07:21 PM
Adcom GFA-585 went bad - calling Adcom experts hangguy Solid State 14 24th December 2004 09:09 PM
oscillating...always oscillating WoulYaShassu Solid State 30 9th April 2004 06:31 PM
Copyright ©1999-2019 diyAudio
