Extremely simple amplifier (4 transistors) with low THD.
Old 20th September 2019, 05:45 AM   #11
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
I ran a quick simulation using commonly available actives for the typical roles here.
Extremely simple amplifier (4 transistors) with low THD.-uno-amp-ltspice-v1-jpg
Increased the operating voltage to 24v and got this:
For 8Vpp (2.83vrms) into 8ohms for 1w:
Code:
Harmonic	Frequency	 Fourier 	Normalized	 Phase  	Normalized
 Number 	  [Hz]   	Component	 Component	[degree]	Phase [deg]
    1   	1.000e+03	4.087e+00	1.000e+00	    2.16°	    0.00°
    2   	2.000e+03	1.525e-03	3.732e-04	  113.93°	  111.77°
    3   	3.000e+03	2.855e-04	6.987e-05	  178.73°	  176.57°
    4   	4.000e+03	2.991e-04	7.319e-05	  178.34°	  176.19°
    5   	5.000e+03	2.397e-04	5.866e-05	 -179.55°	 -181.70°
    6   	6.000e+03	1.984e-04	4.855e-05	 -179.62°	 -181.77°
    7   	7.000e+03	1.701e-04	4.162e-05	 -179.72°	 -181.88°
    8   	8.000e+03	1.488e-04	3.642e-05	 -179.75°	 -181.91°
    9   	9.000e+03	1.323e-04	3.237e-05	 -179.78°	 -181.94°
   10   	1.000e+04	1.191e-04	2.914e-05	 -179.80°	 -181.96°
   11   	1.100e+04	1.083e-04	2.649e-05	 -179.82°	 -181.98°
   12   	1.200e+04	9.923e-05	2.428e-05	 -179.84°	 -181.99°
   13   	1.300e+04	9.160e-05	2.241e-05	 -179.85°	 -182.00°
   14   	1.400e+04	8.505e-05	2.081e-05	 -179.86°	 -182.01°
   15   	1.500e+04	7.938e-05	1.942e-05	 -179.87°	 -182.02°
Total Harmonic Distortion: 0.040360%(0.292814%)
It has 2nd order dominant distortion with a monotonically decreasing profile. So should sound good. I do not see it as particularly low THD though, but that is to be expected of a 4-active singleton amp:
Extremely simple amplifier (4 transistors) with low THD.-uno-amp-ltspice-v1-fft-jpg
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 20th September 2019, 06:20 AM   #12
Got Foam?
xrk971's Avatar
It is able to make 7w into 8ohms with fairly low distortion:
Code:
    1   	1.000e+03	1.075e+01	1.000e+00	    2.16°	    0.00°
    2   	2.000e+03	9.502e-03	8.841e-04	  100.52°	   98.37°
    3   	3.000e+03	2.996e-03	2.788e-04	    7.43°	    5.27°
    4   	4.000e+03	1.224e-03	1.139e-04	 -122.71°	 -124.87°
    5   	5.000e+03	2.125e-03	1.977e-04	 -173.41°	 -175.57°
    6   	6.000e+03	1.677e-03	1.560e-04	  118.78°	  116.62°
    7   	7.000e+03	9.150e-04	8.514e-05	   18.63°	   16.48°
    8   	8.000e+03	1.325e-03	1.233e-04	  -92.76°	  -94.91°
    9   	9.000e+03	1.647e-03	1.532e-04	 -167.37°	 -169.53°
   10   	1.000e+04	1.374e-03	1.278e-04	  120.45°	  118.30°
   11   	1.100e+04	9.276e-04	8.632e-05	   25.36°	   23.20°
   12   	1.200e+04	1.068e-03	9.935e-05	  -82.19°	  -84.34°
   13   	1.300e+04	1.302e-03	1.212e-04	 -161.21°	 -163.36°
   14   	1.400e+04	1.126e-03	1.048e-04	  125.30°	  123.14°
   15   	1.500e+04	7.646e-04	7.114e-05	   33.56°	   31.40°
Total Harmonic Distortion: 0.102280%(0.309343%)
I should add that this is a fairly high bias current of 640mA (sort of Class A) and dissipating about 8w per output active.
Old 20th September 2019, 11:34 AM   #13
anti is offline anti  Slovakia
Amps like that were abundant in 70's, 80's. I've built shitloads of small amps with above topology back then. The ones with germ. outputs (a popular pair was AD161/162) were particularly "good" sounding (had a really good presentation of new-vawe and punk guitars - which used to be popular then). Another popular Si pair for car-radios was BD433/434.
If made with a darlington input (or a bit more heavily bootstrapped than above amp); it can be fed directly from a ceramic cartridge record player (audiophiles beware!)
Old 20th September 2019, 12:28 PM   #14
gannaji is offline gannaji  India
gannaji's Avatar
JLLH class A also uses four transistors !
www.samritatrust.org
Teach me the glorious lesson that occasionally, I might be mistaken. Keep me reasonably sweet.
Old 20th September 2019, 01:44 PM   #15
Got Foam?
xrk971's Avatar
Yes, but JLH did not have push pull output.
One thing I noticed with this amp that is unique: despite having output coupling cap, there is a slight 500mV DC offset due to the connection from the base of the PNP to the output after the cap.
This offset is not a good thing as voice coil will heat up a bit.
Old 20th September 2019, 02:12 PM   #16
Renbrant is offline Renbrant  Brazil
Excuse me. The photo link has broken.
Here you find all the results:
RB Eletronica - UNO
Old 20th September 2019, 02:53 PM   #17
Elvee is offline Elvee  Belgium
Elvee's Avatar
The originals were generally much better than this example: here is a large collection from various sources:
A collection of vintage, single supply, low to medium power amplifiers for Daniel
This one from a Motorola appnote probably served as a model:
I have also described a number of evolutions based on the same theme, and they really bring novel features and good performance.
Otherwise, stick with the good old original circuits: they are still current and usable, unlike some pale copies
. .Circlophone your life !!!! . . ♫♪ My little cheap Circlophoneİ ♫♪
Electrify your daily life!!! ....⚡⚡ ELEKTRIA ⚡⚡
Old 20th September 2019, 03:11 PM   #18
It's almost the same topology.
This is a very cool material!
Old 20th September 2019, 03:54 PM   #19
Got Foam?
xrk971's Avatar
Amps like this are fun to make. You can even do it on veroboard or P2P. They certainly sound nice.
Old 20th September 2019, 04:19 PM   #20
EDDELARUE is offline EDDELARUE  Brazil
EDDELARUE's Avatar
Code:
What about AC analysis ??
eD
Extremely simple amplifier (4 transistors) with low THD.Hide this!Advertise here!
DIY Sony surround amplifier as simple amplifier qkhanhpro Everything Else 4 5th September 2013 03:06 AM
Make Hifi with 3 Triple Sziklai transistors in Simple Class A lineup Solid State 14 15th November 2012 08:08 PM
Extremely cheap headphones amplifier Rullknufs Solid State 49 17th September 2010 04:02 PM
AB Amplifier with clasics transistors Thevenin Solid State 23 6th April 2009 01:53 PM
Looking 4 a simple NPN/PNP Output stage schematic useing Tip31C/32C Transistors?? Minion Solid State 27 20th April 2007 06:50 PM
Copyright ©1999-2019 diyAudio
