BUH150  obsolete replacement wanted -  Class AB Mosfet  Amplifier 1750W RMS
Old 21st August 2019, 10:19 AM   #1
NMOS is offline NMOS  Germany
NMOS's Avatar
Default BUH150 obsolete replacement wanted - Class AB Mosfet Amplifier 1750W RMS
Hi
Problem BUH 150 Transistor is obsolete, cant find replacement
Ecler PAM6100 Swithcing Power Mosfet PA Class AB Mosfet Amplifier
BUH150: 15 AMPERES 700 VOLTS, 150 WATTS
BUH 150 Transistor working as Buffer in PA Mosfet Amplifier to drive IRFP360 Mosfet Array
look schematic
Its N a Channel PA Mosfet Amplifier Rail 140 +/- DC
Class AB 1750W RMS Output Power 4 Ohm
I dont understand the secret why using BUH150 with MJE15031 in Buffer stage,
I dont understand why amplifier not using 2 x MJE instead of BUH150
MJE15034 / 15035 or MJE E15032/ 15033 shuld work too
Old 21st August 2019, 10:21 AM   #2
NMOS's Avatar
The Amplifier have NE5534a input op amp and Wilson current mirror
Old 21st August 2019, 10:42 AM   #3
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
LittleDiode – Electronic Components for All
You can still get BUH150 from LittleDiode – Electronic Components for All
Old 21st August 2019, 01:36 PM   #4
anti is offline anti  Slovakia
The BUH is a "buffer", the MJE is used to speed up mosfets' gate-discharge, ok that's obvious ... perhaps the BUH part has some desirable characteristics that the MJE parts don't have ...?
Old 21st August 2019, 02:56 PM   #5
NMOS's Avatar
Originally Posted by KatieandDad View Post
Yes thanks for Info, but price is jeavy for old stock.
Is there no replacemnet siimilar transistor for BUH150 available ?
BUH150  obsolete replacement wanted -  Class AB Mosfet  Amplifier 1750W RMSHide this!Advertise here!
MAX 5406 ( obsolete ) replacement part alah Parts 1 15th December 2018 03:25 PM
BSS129-obsolete mosfet jcam555 Swap Meet 0 27th October 2015 11:18 PM
Obsolete Transistor Replacement jtubio1 Solid State 5 28th June 2010 10:16 PM
Obsolete Motorola Transistor Replacement KirkW Solid State 13 11th June 2010 01:23 AM
Help with obsolete transistor replacement texaslonghorn Parts 2 19th September 2009 09:24 PM
Copyright ©1999-2019 diyAudio
