Just another lateral FET amp
Old 30th July 2019, 06:31 PM   #21
voltwide is offline voltwide  Ireland
Now there is some work in progress....
tuby or not tuby, that is here the question!
Old 30th July 2019, 08:38 PM   #22
rsavas is offline rsavas  Canada
I have been using JLCpcb for a while now, I think they are great for what they are worth. Cheaper than pcbway, so I am sticking with them.
I have had no data load rejections to date. I made a mistake once and caught it early enough to contact them to scrap the design before it got into production.
I can get them delivered fast with DHL express and pay duties/brokerage or the really slow way with DHL post I guess it is, but it comes via Canada Post and no brokerage/duties.
Good luck with your design voltwide, nice to see pics of your work, I can see how much more assy is required for a TO-3 metal can vs a TO-264 as I have used.
Old 30th July 2019, 10:00 PM   #23
Thank you for the kind wording.
You can see some good reason why this case is obselete
Old 30th July 2019, 10:03 PM   #24
Meanwhile the first module is populated.
File Type: jpg 07_module1_top_IMG_20190730_224130773.jpg (172.9 KB, 230 views)
File Type: jpg 08_module1_bot_IMG_20190730_224111769.jpg (192.7 KB, 219 views)
Old 30th July 2019, 10:05 PM   #25
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
You see a good reason why this case is obselete
I found I could use my pcb as a drill template and get very good results.
I line up pcb with heatsink then clamp pcb to heat sink.
I then drill one of the transistor mounting bolt holes.
I put a bolt through the hole and tighten it down.
I then drill opposite end of heatsink and bolt that down.
You can now drill out rest of the holes through the pcb (with care.)
I have done quite a few this way and never had a problem.
I found for the connecting wire holes a hand held drill was better to stop the drill biting in the wrong place. I put the drill through the pcb hole and start it up slowly.
They are a pain and much harder than single hole transistors but nothing wrong with a bit of nostalgia !
PCBCAD51 and PCBCAD360 out now >>> https://www.murtonpikesystems.co.uk
Old 30th July 2019, 10:07 PM   #26
The case is not really obsolete but certainly not used as much as the past with the newer plastic. TO-3 are more reliable as they are hermetically sealed, so no or little moisture absorption to contaminate in the pressure cooker test.
Old 30th July 2019, 10:08 PM   #27
Originally Posted by Walkalone View Post
Hi Voltwide,
How is the quality of these PCBs? I've ordered many PCBs from Chinese but there is no anywhere i actually feel OK.
Cuong Nguyen
I cannot complain about quality - it is fine. Being a "coarse" design with much clearance requirements are relaxed and it is hard to manufacture scrap.
Old 30th July 2019, 10:16 PM   #28
I do not take the pcb as a stencil but a 1:1 printout from my laser printer, which is sufficiently accurate. With paper stencil I punch-mark and then drill. This is less convenient but I avoid any ugly damage of the pcb.
Old 30th July 2019, 10:20 PM   #29
If you go gently the hole aligns the drill into it.
Also, using an electric hand drill with the drill down the hole before you start stops the pcb hole being widened out.
Old 30th July 2019, 10:30 PM   #30
Some remarks to the actual pcb layout. Being 2-sided big copper filled areas are possible. So I divided the amp into 2 zones: the input zone with LTP ending at the input of the VAS. All nets of this area carry little voltage levels, so they are screened by a copper fill connected to analog GND.
The second zone is the power, carrying all the nets at the high output level. This includes the VAS output as well. This hole area is screened by a copper plane connected to the output. The idea behind this is to minimize the parasitic capacitive loading of the VAS by the well known method of an active screen.
The top view of the pcb shows these two areas, separated by a wide trench acting as "isolation barrier".
And this isolation barrier is bypassed by a minimized bunch of tht resistors and caps.
Just another lateral FET ampHide this!Advertise here!
Lateral MOSFETs JaredC79 Solid State 79 1st March 2016 10:39 AM
double die lateral fet vandenberg Swap Meet 2 20th November 2013 03:28 PM
Lateral F4/BA buzzforb Pass Labs 16 21st October 2011 04:30 AM
Lateral FET and Rds on? AndrewT Everything Else 2 27th December 2005 08:05 PM
lateral vs vertical,P vs N Leolabs Pass Labs 3 15th February 2005 07:01 PM
Copyright ©1999-2019 diyAudio
