Just another lateral FET amp
Old 24th July 2019, 09:07 PM   #11
voltwide is offline voltwide  Ireland
This is not so evident, but nonetheless easy to explain. The pcb will be mounted parallell to a heatsink (200*300*20mm) in a short distance of approx 10mm. Each TO-3 will be mounted onto an alu profile 50*100mm, 3~4mm thick. This will be mounted on a massive alu rod (10*10 upto 20*20mm, 100mm long). The resulting heat conductor will be screwed to the aforementioned big heatsink (I have just a pile of them, stored since the eighties)
tuby or not tuby, that is here the question!
Old 24th July 2019, 09:14 PM   #12
Originally Posted by Tournesol View Post
Nice VFA, Voltwide. I like the current mirror.
Just a question, how are-you going to cool the HEXFETS ?
Btw, there are no HEXFETs, and the hole circuit is not designed for them.
Old 25th July 2019, 12:32 AM   #13
Tournesol is online now Tournesol  Belgium
Tournesol's Avatar
The Hitachi MOSFETs, sorry ;-)
Yours faithfully,
Tryphon Tournesol
Old 25th July 2019, 01:09 AM   #14
tsmith1315 is online now tsmith1315  United States
tsmith1315's Avatar
Neat, thanks for posting. You're lucky to have those metal can FETs to play with!
Tim
Old 30th July 2019, 08:52 AM   #15
After a lot of hassle with AllPCB, DHL express and the customs I finally received the PCBs. As a result AllPCB now is on my personal "ignore list".
File Type: jpg pcb_bot_IMG_20190730_102801775_HDR.jpg (157.5 KB, 626 views)
Old 30th July 2019, 02:41 PM   #16
Walkalone is offline Walkalone  Viet Nam
Hi Voltwide,
How is the quality of these PCBs? I've ordered many PCBs from Chinese but there is no anywhere i actually feel OK.
Cuong Nguyen
Old 30th July 2019, 02:51 PM   #17
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
nice project.
just curious to know if have you looked at the clipping behavior?
mlloyd1
Old 30th July 2019, 04:26 PM   #18
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Originally Posted by Walkalone View Post
Hi Voltwide,
Cuong Nguyen
I use JLCPCB mostly but have used PCBWAY.
The quality has been amazing even on fine scale SMD with very small via's.
I sometimes get JLCPCB rejecting my files for silly reasons.
I just resend the same files and next time someone different scans them and they go through.
PCBCAD51 and PCBCAD360 out now >>> https://www.murtonpikesystems.co.uk
Old 30th July 2019, 05:21 PM   #19
Originally Posted by mlloyd1 View Post
nice project.
mlloyd1
Thank you. I did not check this seriously in simulation - waiting for real result to come. But there will be 2 clamp diodes providing unsaturated clipping in case the driver circuit will be fed by some bootstrapped supply (refer to aux supply).
Old 30th July 2019, 05:27 PM   #20
The trouble with Allpcb was they offer "DHL" - but they send by DHL-express. Being asked they strictly deny DHL-express - although I have the 1.hand information from DHL-express that AllPCB is their customer. So, whom do you think I will believe?
Just another lateral FET ampHide this!Advertise here!
Lateral MOSFETs JaredC79 Solid State 79 1st March 2016 09:39 AM
double die lateral fet vandenberg Swap Meet 2 20th November 2013 02:28 PM
Lateral F4/BA buzzforb Pass Labs 16 21st October 2011 03:30 AM
Lateral FET and Rds on? AndrewT Everything Else 2 27th December 2005 07:05 PM
lateral vs vertical,P vs N Leolabs Pass Labs 3 15th February 2005 06:01 PM
Copyright ©1999-2019 diyAudio
