Just another lateral FET amp
Old 22nd August 2019, 06:33 PM   #121
voltwide is offline voltwide  Ireland
Today I brought in an Audio Precision Portable One Plus. Not the bleeding edge nowadays, it was built in the 90ties. Nonetheless its generator output delivers upto 30V output level with less noise than my sound card. So I fed the amp using the AP while recording the spectrum with my soundcard at 18Vrms output into 10R - just below clipping comes in.
tuby or not tuby, that is here the question!
Old 22nd August 2019, 06:43 PM   #122
Noise floor dropped below 150dB, THD=0.00027%, THD+N=0.0034%.
Feeding the output into the AP input yielded this result:
Old 22nd August 2019, 06:48 PM   #123
synonymous is offline synonymous  United States
Send a message via MSN to synonymous
You are having a blast I can see
Old 22nd August 2019, 06:50 PM   #124
It is a pity the AP does not offer bare THD but only THD+N. The result is 0.001% being 3times below the readout of the soundcard. This confirms lower noise of the AP - anyway THD measurements are at their limit as well.
Old 22nd August 2019, 06:53 PM   #125
Is it the AP display you are referring to? There is a problem with the backlight as well.
Old 22nd August 2019, 10:33 PM   #126
Mark Tillotson is offline Mark Tillotson
BTW You can't measure noise floor from a power spectrum plot, you need the power spectral density plot for that, because noise depends on bandwidth and you have to correct to unit bandwidth and correct for the window function noise-bandwidth.
Old 22nd August 2019, 10:55 PM   #127
I am aware of that. What I did is comparing both noise floors with the same setup of FFT bins. And the observation that there is more noise with the soundcard than with the AP is backed up by the THD+N numbers imho.
Old 22nd August 2019, 11:01 PM   #128
The display is faint, i.e. backlight is dim. So I looked for the backlight supply inside the AP. A small 60Hz xformer delivers approx 150Vac, so I think this is ok. Or have these LCD from the nineties all been that faint and I have simply forgotten the old ones?
Old 26th August 2019, 06:05 PM   #129
Meanwhile I updated the change log and reworked the pcb layout accordingly. By minimizing the length of sensitive traces I hope to improve 50Hz hum screening.
Old 26th August 2019, 06:10 PM   #130
This is the actual kiCAD preview:
Just another lateral FET ampHide this!Advertise here!
Lateral MOSFETs JaredC79 Solid State 79 1st March 2016 10:39 AM
double die lateral fet vandenberg Swap Meet 2 20th November 2013 03:28 PM
Lateral F4/BA buzzforb Pass Labs 16 21st October 2011 04:30 AM
Lateral FET and Rds on? AndrewT Everything Else 2 27th December 2005 08:05 PM
lateral vs vertical,P vs N Leolabs Pass Labs 3 15th February 2005 07:01 PM
Copyright ©1999-2019 diyAudio
