Why is there Steel Wire in my Harman Kardon HK6100?
Old 7th July 2019, 11:20 PM   #1
Spinifex is offline Spinifex  Australia
Default Why is there Steel Wire in my Harman Kardon HK6100?
Can someone allude to why there are steel wires in my Harman Kardon Amp? I am wanting to re-route some wire and have discovered, somewhat to my consternation, that several of the wires leading to the speaker terminals and from the mainboard its self, are made of STEEL, not copper.
1. What is with STEEL WIRES being used in my HK6100?
2. I want to replace the steel wires with copper of higher quality and thicker gauge - will I notice any difference by 'upgrading the wires' to a size that suites my re-routing attempts to move the speaker terminal wires further away from the transformer?
The wires running from the speaker selector switch bottom right pass a inch away from the transformer to the speaker terminals top-mid right. I want to re-route the wires around the heat sink to bypass the transformer completely.
Old 7th July 2019, 11:37 PM   #2
rayma is offline rayma  United States
Are they magnetic? That is considered ok by much of the audio "establishment".
Replacing them with standard copper wires certainly can't be any worse.
Be sure to strain relief the connections.
Old 7th July 2019, 11:42 PM   #3
Ian Finch is offline Ian Finch  Australia
Obvious question; how did you determine that the wires were steel?
If only I had listened....
Old 7th July 2019, 11:50 PM   #4
kokoriantz is online now kokoriantz  Lebanon
For the same reason why electrolytic, ceramic , high quality capacitors , metal case transistors have iron content (magnetic ) leads .
Old 8th July 2019, 12:30 AM   #5
nironiro is offline nironiro  Croatia
Why is transformer changed?
Old 8th July 2019, 12:51 AM   #6
I don't know. It's not mine. Mine is original. I got the photo from another thread: Harmon Kardon HK6100
They look like they are and they are also really 'stiff'. Photo of my HK6100 20190706_182920.jpg 20190706_183215.jpg
The wires from the 'speaker selector switch running to the 'speaker distribution board are as stiff as [insert expletive]. My guess is that they are 4x single core solid steel judging by stiffness and colour of the wire. The wire is NOT copper (not even tarnished copper) but are steel or aluminium colour and my guess is they are not aluminium.
The reason I am 'willing to rewire' my HK6100 is that one of the the speaker 'knobs' is broken and I've opened it up in order to do a 'Ghetto Fix' on it. For that I have to 'remove the speaker' distribution board and will effectively have 'unwire' the speaker distribution board anyway, so wiring in some heavy gauge stranded copper wire (which I already have) and re-routing the wire away from the transformer, will be a non-issue and I may as well do it anyway. 20190706_183049.jpg
Old 8th July 2019, 01:53 AM   #7
gofar99 is offline gofar99  United States
gofar99's Avatar
Hi, I have seen tin plated wires like that and even silver wires. The latter are quite stiff usually.
Good Listening
Bruce
Old 8th July 2019, 04:55 AM   #8
Well, I've also encountered copper wires that are stiff because they either have very few strands, or the PVC sleeving has aged (lost the plasticiser) and become stiff. Good quality stranded copper wire used for soldered assembly is usually tinned anyway, so it doesn't appear pink like copper either - it looks like bright tinplate as you'd expect.
Soldering steel wire connections by hand assembly would also be a dicey procedure - I can't see why anyone would do it on a 30+30W budget amp anyway.
How about using a magnet to test for ferric properties? That sure beats guessing.
Old 11th July 2019, 10:31 PM   #9
The Magnet Test was 'inconclusive' because I couldn't find a magnet I had confidence in, and also because there appeared to be no magnetism from the dodgy magnet I did use.
I have finished rewiring the speakers jacks and in doing so 'left institu' the original neutral/return wires and wired them up to my D.I.Y. custom speaker jacks... and had the opportunity to take photos. They were very hard to strip and cut - ie: Strong - but maybe aluminium or some such. Photos attached:
Old 11th July 2019, 11:03 PM   #10
Default Finished Project - HK6100 rewired
As an aside from the original question of 'Why are steel wires inside my HK6100' I've now finished my project. I've repaired the speaker jacks by fabricating an new custom speaker jack from cannibalised parts and MDF. I re-cabled the original cable running from the speaker selector switch to the speaker jacks because I believed it was running too close to the transformer. I've also Deoxit'ed all the dials and volume control to remove the tarnish buildup that was causing static and some hum.
I'm not sure of the Deoxit or the Re-Routed speaker connector wires away from the transformer was responsible for eliminating the hum, but the hum is gone.
Photos attached:
Why is there Steel Wire in my Harman Kardon HK6100?Hide this!Advertise here!
Harman Kardon HK6100 Idling current Phil50 Solid State 4 8th July 2019 05:26 PM
Harman Kardon PM 665 vxi coachmorin Solid State 7 25th March 2015 03:24 PM
Harmon Kardon HK6100 demons_wing Solid State 12 18th March 2012 09:07 PM
For Sale Harman Kardon T60 Turntable / Harman Kardon Cd491 Cassette Deck electric blue Swap Meet 1 25th August 2006 11:36 PM
Harman Kardon amp Ilianh Solid State 10 26th December 2005 03:27 PM
Copyright ©1999-2019 diyAudio
