Pizzicato, a 200W low distortion CFA amplifier
Old 20th July 2019, 05:59 PM   #141
rsavas is offline rsavas  Canada
Good luck guys on your design efforts.
Old 20th July 2019, 09:23 PM   #142
Tournesol is offline Tournesol  Belgium
Tournesol's Avatar
Originally Posted by Krisfr View Post
1-Where will the additional parts go?
2-Also how do you want to make the 12 volts, with resistor zener and cap?
I don't know, Krisfr. What is your opinion ? I thought on a separate little board to let users to chose or not protection etc... ?
I think it would be better to add a separate litle psu for 12V's. That come, by habit with SMPS, by example. And keep the amp itself simple ?
This way it will be used for whatever we want for comfort: Remote, soft start, silent stop, fans, temperature sensors and fan command if any, etc. without any impact on the PSRR.
BTW, may-be it should be careful, on your schematic of OPAMPS, to add a comp cap in parallel with the feedback resistance of the "2", just in case ?
Yours faithfully,
Tryphon Tournesol
Old 20th July 2019, 10:12 PM   #143
spladski is offline spladski  United Kingdom
One thing to have in your back pocket is the temperature compensation for the input stage. The zeners have a tempco of around -2mV. A blue diode is double this. An investigation of different input devices hasn't been made yet. It does appear the input stage has quite a bit of sensitivity regarding change of device.
The concept of the input is to have the same current operating in both transistors of the cascode. Change of device easily generates an imbalance.
Old 21st July 2019, 01:47 PM   #144
Tournesol's Avatar
Spladski, thanks A LOT.
I just tried a step temp simulation in LTSPICE. You are right, the bootstrap is catastrophic and need to be addressed.
Between 0 to 50°, while the current source only vary form 1.22mA to 1.18 mA, the cascode current goes from 44mA to 0mA, the driver current goes from 90mA to 0, and the output devices current from 750 to 0 mA.
I cannot believe-it !
Surprised, because, apart this front end, it is a topology I'm used to, IRL, without major issue.
All helps appreciated.
Krisfr, I think it is necessary to fix this major issue before going further in the board design.
Yours faithfully,
Tryphon Tournesol
Old 22nd July 2019, 10:17 AM   #145
Tournesol's Avatar
So, at the end, bootstraping the input stage was a false good idea. Back to the original design with the addition of the traditional biasing transistor.
As the HEX and Lateral Power FETS stabilize themself around 100/150mA, it has not to be on the PowerFETs cooler.
The advantage is that in case of a bad contact of the adjustable resistance, the bias will decrease.
A simple diode had been added to the current sources zeners to give them tempco.
Like this it is over compensated. I still have to see how it behaves without them but with the biasing transistor alone.
The schematic will be something like this, I still have to refine the current values and optimize feedback compensation network.
Schematic under, just to give an idea.
Yours faithfully,
Tryphon Tournesol
Old 22nd July 2019, 01:21 PM   #146
LKA is offline LKA  Europe
LKA's Avatar
Very nice amp and results. I don't like compensation C16,17.
Btw, can you beat this ?
200W/4R (VFA TMC+CHERRY+EC) less than 1dB under clipping
Old 22nd July 2019, 02:28 PM   #147
Krisfr is offline Krisfr  United States
Krisfr's Avatar
Okay, I will work on the output area and wait for the front end later.
Please choose a layout style to use for the output area.
Never give a Systems Analyst a screwdriver or hammer
Old 22nd July 2019, 02:46 PM   #148
mlloyd1 is online now mlloyd1  United States
mlloyd1's Avatar
How about Style 1 but with alternating adjacent P and N devices?
mlloyd1
Old 22nd July 2019, 03:23 PM   #149
Krisfr's Avatar
mlloyd1
Exactly !
Old 22nd July 2019, 04:49 PM   #150
Tournesol's Avatar
Originally Posted by LKA View Post
1 -Very nice amp and results.
2 -I don't like compensation C16,17.
3 -Btw, can you beat this ?
1 -Thanks, LKA.
2- I don't like-it neither, but not found a better way.
3- Certainly not with a CFA ;-) (Congratulation. Any link to the thread ?)
Yours faithfully,
Tryphon Tournesol
Pizzicato, a 200W low distortion CFA amplifierHide this!Advertise here!
200W mosfet Amplifier sanbadgujar Solid State 20 31st August 2012 07:46 AM
"State-Of-MOS": 200W Ultra Low Distortion Pure FET Amplifier MagicBox Solid State 137 19th July 2012 01:13 PM
200W PA amplifier mihailo PA Systems 16 19th June 2010 05:18 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 07:49 PM
200w Amplifier question BritKat Solid State 4 22nd March 2003 06:41 PM
Copyright ©1999-2019 diyAudio
