Advent 300 Receiver Question
Hi folks,
Working on this receiver and notice that the output offset on one channel is what I believe to be too high (50mv) versus the other channel's 5mv.
Schematic here:
https://davidreaton.com/wp-content/uploads/2016/08/Advent-300-newer-Amplifier-schematic.pdf
Notice that it uses a number of differential pairs in the inputs and was wondering if I should remove a few of them, and try to match the gains of transistors in input of the "offending" output section channel to lower the offset - or could you suggest another way to lower this.
And while we're at it - can you suggest any other tweaks
THANKS
Charles
I just acquired one of these Advent 300's. It looks like it might have an issue as the 3A fuse is blown so I wont be plugging it in until I've gone through a test procedure to find where the short is.
It's a neat little receiver though and I'm keen to get it cranked up.
Regards John
