Apex A40 Amplifier Build Thread
Old 10th June 2019, 06:00 PM   #21
burnmaster is offline burnmaster  Bulgaria
Respect to alex mm and maxwell007.
You have built extremely beautiful devices.
Whatever I do, my devices look like they're made with an ax.)))))
And other times I've been showing my old A40, but in the spirit of the theme again.
YouTube
A40 became my favorite when I was in a direct match over my previous favorite .....
A40 sounds better.
YouTube
Old 12th June 2019, 10:40 PM   #22
rehman is offline rehman  Pakistan
Originally Posted by apexaudio View Post
Your option is A40, SR300, B500, HV23...
hi sir. i have build A40 a day ago and tested. there is an issue. the issue is with offset pot. when power supply is connected there are some voltage at output and offset pot does not do any thing to offset voltages. other than that two transistors MJE340 and 350 at input stage are heating up without any signal. pcb is my own designed.
Old 13th June 2019, 02:00 AM   #23
asuslover is offline asuslover  Romania
I'm happy you started this thread.
These are some picture of the power transistors could be used for this amp.
Old 13th June 2019, 07:40 AM   #24
shahzad831 is offline shahzad831
Hi rehman
I would suggest u to check ur pcb. Yesterday i assembled A40 on alex's PCB , started at first tym. Mjes are in VAS get hot no problem with it. Just review ur pcb its better to use alex,s .
Old 13th June 2019, 07:53 AM   #25
Hi rehman
Old 13th June 2019, 08:28 AM   #26
Originally Posted by shahzad831 View Post
Hi rehman
thanks for reply. i have attached my pcb if you can look on it. if you have unmirrored black pcb layout of alex,s pcb then give me please. i realy want to build this amp.
Old 13th June 2019, 10:03 AM   #27
Originally Posted by alex mm View Post
Hi all,
The latest revision of PCB Will be ready this summer .
BR Alex
hi alex. i have some issues with my pcb. i cant adjust offset with pot. is there should be 470k or 470R resistor and is it normal for mje340, 350 at input side to get hot even on low operating voltages ?.
Old 13th June 2019, 05:00 PM   #28
Originally Posted by maxwell007 View Post
My build...
can you give me files please?
Old 13th June 2019, 05:38 PM   #29
rehman.....I do not understand English well, but as far as I understand you have a problem with the scheme.
If the board is executed correctly, there should be no problem, and it works from the first time.
You have to be careful with the bindings and there is no shortage of tracks. It happened to me but I found it.
I would help with what I can, but the language is very disturbing to me.
Please someone help him urgently because this man deserves the A40.))))
Old 13th June 2019, 06:31 PM   #30
just one last question please someone solve my confusion. which of the following is 100% working and ok PCB??. which one should i made.?? should there be 470R or 470K resistor with offset pot?
File Type: pdf APEX A40 CFA ALL CRAY RED BLACK TOP VIEW By ALEX MM rev1.4.pdf (278.3 KB, 23 views)
Apex A40 Amplifier Build ThreadHide this!Advertise here!
4 way active amplifier build thread and questions drivemusicnow Class D 6 10th May 2019 01:20 PM
monster-6-channel-amplifier-build-thread matt09 Solid State 8 12th April 2016 09:44 PM
"The Very Best Amplifier I Have Ever Heard!!!!" Build thread. Boscoe Solid State 8 31st January 2011 05:02 PM
Home Thread-Apex Jr Variac Apex Jr 0 21st August 2009 09:56 AM
Build an Apex based CD player..harddrive?? mpmarino Digital Source 8 3rd February 2009 09:10 AM
Copyright ©1999-2019 diyAudio
