Apex A40 Amplifier Build Thread
Old 10th June 2019, 09:10 AM   #11
shahzad831 is offline shahzad831
Operating voltages??
Old 10th June 2019, 12:04 PM   #12
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by shahzad831 View Post
Hello every one
Is it possible to feed A40 with +/-75vdc? Output devices are sanken's a1216 c2922.
Yes you can feed A40 with +/-75vdc.
Old 10th June 2019, 12:10 PM   #13
Any modification?? Change in resistence values and bias
Old 10th June 2019, 02:01 PM   #14
apexaudio's Avatar
No changes
Old 10th June 2019, 02:03 PM   #15
burnmaster is offline burnmaster  Bulgaria
Hi shahzad831. Hope you know what I'm saying because I'm using an online translator. Which I changed into my future A40 and I hope it is good. To double the power I build 2 monoblocks, each block having 2 bridge boards. I use on powerful transistor terminals. I raised the current in the 800mA final resistors ... you probably call it a bias. The end transistors are very expensive, so I use big radiators. Extremely strong I have emphasized on the capacities, as I am convinced that they bring the good sound.)) For each monoblock are provided 250,000mF. For the whole amplifier 500,000mF .... or in short, half Farad.) Previous tests passed successfully. The good thing in this case is that every monoblock due to the bridging connection will use XLR connectivity, and also my oppo sonica dac has a fully balanced XLR output.
I hope I've been helpful. Greetings.
Old 10th June 2019, 02:16 PM   #16
Thanks for feedback guys. Actually i have some numbers of orignal sankens in stock ao i want to utilize them in a40 or sr200 . Issue is this, that i have an SMPS (based on 2110 3525 ETD 59 DIY) whos output is +/-75vdc 10 amps . And i want to put that smps on job. What will be the best option SR200 or A40? Which amp have low THD and good temprature average. My speakers are peavey SP2. Thanks for your precious feedback.
Old 10th June 2019, 03:54 PM   #17
apexaudio's Avatar
Your option is A40, SR300, B500, HV23...
Old 10th June 2019, 04:26 PM   #18
Then i will go for A40 nice symetrical design. I didnt saw Hv23 schematic yet i will try to search it
Old 10th June 2019, 05:19 PM   #19
AdeS is offline AdeS  Brazil
AdeS's Avatar
Take a look here, shahzad831!
Old 10th June 2019, 05:42 PM   #20
shabusf is offline shabusf  India
Hello Friends, Below are my build details. Trafo: 39-0-39, 5A per channel. Dual Mono. Drivers: MJE15028/29 (rated @120v, but i hope it is okay for +-54v dc ) sourced from RS components. Outputs: Toshiba 5200/1943, sourced from taydaelectronics. BC550/BC560/BD139/MJE340/50 - Sourced from RS Components.
I used Alex MM's 1.4v PCB (the offset series resistor should be 470k, that is the only change from the silk, otherwise populated components as per the silk). If you use 1.5v PCB, silk is having the correct value 470k it seems.
Bias: ~45mA, Offset +-5mV
Use genuine components, your amp will be up without any issues. And of course you will never get disappointed with the sonic, a great sounding amp
As of now I have only two pairs at the output, adding the other one soon.
Happy time for the Apex A40 fans
YouTube
Regards, Sha
Apex A40 Amplifier Build ThreadHide this!Advertise here!
4 way active amplifier build thread and questions drivemusicnow Class D 6 10th May 2019 01:20 PM
monster-6-channel-amplifier-build-thread matt09 Solid State 8 12th April 2016 09:44 PM
"The Very Best Amplifier I Have Ever Heard!!!!" Build thread. Boscoe Solid State 8 31st January 2011 05:02 PM
Home Thread-Apex Jr Variac Apex Jr 0 21st August 2009 09:56 AM
Build an Apex based CD player..harddrive?? mpmarino Digital Source 8 3rd February 2009 09:10 AM
Copyright ©1999-2019 diyAudio
