DIY Class-A 2SK1058 MOSFET Amplifier Problem
Old 8th June 2019, 07:25 AM   #21
hifisucks is offline hifisucks  Germany
hifisucks's Avatar
Forgot where I purchased the k1058s... but I will now never again buy from eBay or such areas...
Old 8th June 2019, 02:04 PM   #22
ivanlukic is offline ivanlukic  Serbia
hifisucks,
I am inclined to believe that everything is OK with your amp and the problem is that you don't understand the circuit you are using. With 24VDC it is perfectly OK to have 11VDC (around one half of supply voltage) on the amp side of output cap. The loudspeaker cone movement at turn on is also OK for most amps, not only single supply kind.
If you are "dazed and confused" (like Led Zeppelin once was) play your amp on some cheap speaker for test.
It's easy to conclude if your K1058 is original. Only lateral MosFETs like K1058 have GSD pinout. See the pic in the original project.
The world has enough for every man's need, but not enough for every man's greed. Gandhi
Old 8th June 2019, 02:34 PM   #23
hifisucks's Avatar
Yes, I didnt understand the curcuit ... but I knew how to set Bias for each channel...
One guy on the analog-forum here in germany said to controll the offset output...
And I didnt think right... so I just stuck the meters in + and - without load... :-)
Not thinking about the curcuit... :-)
I have original Hitachi 2SK1058... :-)
All the best!
Old 14th June 2019, 02:11 PM   #24
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
REICHELT!
That's next door to you ....
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 14th June 2019, 02:39 PM   #25
hifisucks's Avatar
You are right, I buy lot at Reichelt... be at that time he had no k1058s... :-)
All the best!
Old 14th June 2019, 02:53 PM   #26
I am into the exact same project but with a slight modification, a triode driver.
2SK1058 Hybrid Amp
But lack of ideas for a suitable chassis has stopped the project so far.
/Magnus
Old 15th June 2019, 07:11 AM   #27
thimios is online now thimios  Greece
Originally Posted by soundbrigade View Post
REICHELT!
Buy Exicon from Profusion.
Original for sure.
DIY Class-A 2SK1058 MOSFET Amplifier ProblemHide this!Advertise here!
2sk1058 mosfet amp tubem Solid State 38 16th September 2017 02:22 AM
Modified 2sk1058 mosfet amplifier techn0 Solid State 6 12th October 2016 11:46 AM
(ask) ZCA 2sk1058 mosfet amplifier miftah Solid State 15 3rd May 2014 11:15 PM
Mosfet power amplifier 2SJ162/2SK1058 djuke Vendor's Bazaar 29 11th March 2012 12:07 AM
2sk1058 mosfet amp tubem Introductions 1 20th July 2010 02:46 AM
Copyright ©1999-2019 diyAudio
