Lateral CFA 120W - BSA
Old 8th June 2019, 11:00 AM   #21
dadod is offline dadod  Croatia
dadod's Avatar
There is one interesting possibility to change a bit THD and harmonic shape at high frequencies, at 20kHz, by changing value of R20, the two pole compensation resistor.
Original value is 1k5 but could be lowered down to 220R and THD20k goes down, harmonics get more euphonic. Downside is lowering the Phase Margin but still stays very stable.
This could be done wile listening and decide what is better.
Old 8th June 2019, 11:46 AM   #22
johnego is offline johnego  Indonesia
So it's true that certain compensation scheme can be used to tailor the distortion spectrum. I tend to search for the simplest compensation, which is critical for low bandwidth amplifiers, and an easy load for the driving stage.
Old 9th June 2019, 08:24 PM   #23
dadod's Avatar
This amp is simple to put in pure ClassA, 40W/8ohm and 80W/4ohm.
File Type: jpg 40W-ClassA-lateral-simple-FFT1k10_8.jpg (172.0 KB, 425 views)
File Type: jpg 40W-ClassA-lateral-simple-FFT1k40_8.jpg (167.2 KB, 401 views)
Old 10th June 2019, 05:05 AM   #24
Indiglo is online now Indiglo  Australia
Just curious (as in an engineering exercise for the 120 Watt BSA version) can a pair of ecx10's drive a 4 Ohm load ?
It seems based on the SOA curves probably not.
Would the output stage require an extra pair of mosfets ?
What about substituting the ecx10's for the ecw20's ?
In either case I guess the driver stage would need to be modified for the additional ecx10 or ecw20 mosfets ?
Old 10th June 2019, 06:25 AM   #25
dadod's Avatar
Simulation shows it can drive 4 ohm at full power.
You can use one pair of ecw20 mosfets instead two pairs of ecx10, and to use 2 pairs I am not sure yet.
http://www.exicon.info/PDFs/ecx10n20.pdf
File Type: jpg 40W-ClassA-lateral-simple-85W_4-SOA.jpg (148.3 KB, 345 views)
File Type: jpg 40W-ClassA-lateral-simple-20W_4-SOA.jpg (140.4 KB, 340 views)
Old 10th June 2019, 07:37 AM   #26
Thanks for the information, if I read your charts correctly then 4 ohms at 50vdc will exceed a pair of ecx10 mosfets soa curve.
For the BSA 120w amplifier to operate into a 4 ohm load it is necessary to lower the dc rail voltage.
I guess to have the BSA 120w amp capable of operating unconditionally into either a 4/8 ohm load is to add additional ecx10's albeit with a different pcb layout or substitue with a pair of the ecw20 variant which would probably require component changes in the driver stage.
Old 10th June 2019, 08:19 AM   #27
dadod's Avatar
Have you looked ClassA schematic, there is +-35V of power supply?
This amp is 80W on 4ohm.
Old 10th June 2019, 12:06 PM   #28
I've now worked out that I was looking at this from the wrong angle and interpreted the mosfet soa curves from the datasheets from a dc voltage perspective and not the ac rms voltages and thusly the current and rms power into the load or do we use the peak ac voltage and current ?
If that is the case then reduce the dc rail voltage to give 100w into 4 ohms which is plenty of power for a typical room at home
Old 10th June 2019, 07:26 PM   #29
MiiB is offline MiiB  Denmark
You can take the pre-driver stage out, stability will improve, a little higher distortion, but more music
Old 10th June 2019, 08:34 PM   #30
dadod's Avatar
There is no predrivers and stability is very good, no need for improve.
PM=84 degree and GM=18dB.
Lateral CFA 120W - BSAHide this!Advertise here!
L12-2 CFP Output amp 120W*2 8R ljm_ljm Solid State 327 20th June 2019 10:45 AM
120w sub amp BunBun Class D 0 13th March 2014 11:37 PM
LM4780 120W Anuncios360 Swap Meet 0 25th February 2011 01:46 PM
Laptop 90W-120W? di4kata Power Supplies 13 4th May 2006 01:22 PM
120W MOSFET amp. Lamicz Solid State 8 26th January 2006 04:37 PM
Copyright ©1999-2019 diyAudio
