Howto - Distortion Measurements with REW
Old 31st May 2019, 02:06 AM   #21
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
REW also permits frequency sweeps as Chede showed here for his SissySIT amp. It lets you see the various harmonic distortion levels as a function of frequency, plus the main amplitude response flateness and phase. Very nice info - thank you, Chede.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 31st May 2019, 02:53 AM   #22
Got Foam?
xrk971's Avatar
This is a manly-man's dummy load: 200w and 4ohms. I have a voltage divider connected to the differential +ve and -ve inputs on the ring and tip (respectively) of a 6.35mm TRS plug so that it can go into the balanced input of a Focusrite 2i4.
These monster wire-wound rheostat style dummy loads are $15ea on eBay, in case you are interested. I will be using these to test a 200w into 4ohms Class D amp (80Vpp). Definitely need a voltage divider on this one.
Howto - Distortion Measurements with REW-200w-4r-dummy-load-rig-jpg
Old 31st May 2019, 08:31 AM   #23
chede is offline chede  Germany
... fascinated by amps
chede's Avatar
Originally Posted by xrk971 View Post
Hi Chede,
Thanks so much for trying this out. Your Focusrite 2i2 shows excellent performance on the loopback. I just ordered the 1kHz ppm oscillator - seems essential to reach the 0.0008% THd figure that you got.
I’m curious if you used the balanced differential input to the Focusrite or just single ended using and XLR to RCA adapter?
Hi X,
actually, I just used the oscillator in REW, set to - 3dB with 24 bit dither. For signal out, just a simple Cordial patch cable with TS plugs, going from Focusrite 2i2 output either directly into the Focusrite input, or via the attenuator box. That box, albeit basically only a resistor divider, adds a bit of 2nd harmonic distortion, however (don't have a measurement picture with me here in the office now).
So, it's Focurite as signal generator, set to 0.707 V output via the master volume. Since it's TS, only single-ended connections. Into the amps I go via a TS - RCA adapter.
Laptop used is a Lenovo Thinkpad S440 with SSD hard disk and 8 GB RAM, if that might be some contributing factor also.
Best regards,
Claas
Old 31st May 2019, 08:40 AM   #24
chede's Avatar
Your SissySIT amp measurements look great too. The profile on that amp must sound wonderful. I see a forest of noise from the mains though. You might consider an SLB to help smooth some of that out.
Hi X,
yeah, the PSU-related noise is really interesting (measurements here: SissySIT).
The biggest spectral lines are at 50 Hz (mains frequency) and its odd harmonics. That would be radiated noise from the transformer and nearby equipment / mains wiring, at least for the fundamental, not completely sure about the odd-order harmonics. I would think your SLB would mostly be effective in bringing down 100 Hz component and its harmonics ?
Interesting is the 30 Hz sub-harmonic. Can't recall the mechanism that would produce a 30 Hz sub-harmonic, as seen on the right channel, since there is no 60 Hz anywhere in our electrical system. On the left channel, it is 25 Hz, though ...
Best regards, Claas
Old 31st May 2019, 12:03 PM   #25
Got Foam?
xrk971's Avatar
Hi Chede,
That mains spectrum of 50Hz, and 100Hz from the rectifier and it’s harmonics are really something. I saw same thing in my M2 and had a thread on it. I think it’s EMI from the transformer that is picked up by the amp itself. I moved the trafo outside of the amp case and it went away partially. Replacing the linear PSU with a SMPS takes it away too. I think there are some strong EMI noise radiated from those trafos.
The 30Hz puzzles me too as I don’t see how you can generate 30Hz from any difference frequency of 50Hz and it’s harmonics? Maybe you have something in your vicinity that has a 60Hz inverter (maybe a neighbor has one)?
Here was my forest of noise from the M2 a few years ago:
Old 2nd June 2019, 01:43 AM   #26
Eric is offline Eric  United States
Eric's Avatar
Thanks for the writeup on this, xrk!
You can get similar ones rated at 120w for $6 each from MPJA. They have a number of ohmic values. I purchased four 16R resistors and put a wall switch between two pairs, so I have both a 4R at 480w capacity and 8R load at 240w capacity with the flick of a switch.
Now I'll add a voltage divider to it so I can run the output into my PC for analysis.
DIY Theater, Aleph-X Amps, LDR based BA-3 pre, B1 Korg, Pearl II, modified SL-1200 TT, F4, M2, Aleph-J, MoFo, a40, ACAs, FHXL & TB 1772 speakers
Old 2nd June 2019, 02:13 AM   #27
Got Foam?
xrk971's Avatar
Thanks for the tip Eric! That’s a nice setup you have there. Great idea to use wall switch for changing between 4ohms and 8ohms! What amps are you testing that make 480w!!?
Old 2nd June 2019, 02:22 AM   #28
Eric's Avatar
Ha- I was more interested in 4R than 480w. I made this when I was testing my big Aleph-X amps, but they "only" produce 150w into 4R. When you drive real power into these resistors, they get rather warm and turn a bit yellow in color until they cool back down again...
Now I'll add a pair of small resistors and an RCA jack!
Old 2nd June 2019, 07:20 AM   #29
Got Foam?
xrk971's Avatar
I bought the Akitika 2ppm 1khz excitation source and assembled it in about an hour. Very nice projext and super easy to build. I tried it out on the new Yarra-Melbourne preamp.
Howto - Distortion Measurements with REW-yarra-test-2ppm-osc-jpg
Here is 2.0Vpp into a 10kOhm load (about 0.00088% THD and mostly 2nd and 3rd harmonic):
Howto - Distortion Measurements with REW-yarra-melb-0-707vrms-10kohm-fft-jpg
The loopback with just the 2ppm source gave me 2.4ppm (0.00024% THD)
Old 2nd June 2019, 10:01 AM   #30
AKSA is offline AKSA  Australia
That is a phenomenal set of measurements!!
Thanks for giving them X!
HD
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Howto - Distortion Measurements with REWHide this!Advertise here!
Distortion and Other Measurements ????? SyncTronX Equipment & Tools 8 29th April 2014 06:57 AM
Distortion measurements, THD, IMD-what card? Eugene Dvoskin Solid State 24 1st January 2011 06:11 PM
Distortion Measurements Nikon1975 Tubes / Valves 8 1st March 2010 12:57 PM
How to do IM distortion measurements? Conrad Hoffman Parts 1 28th May 2007 06:09 PM
Distortion measurements Vg Multi-Way 5 13th August 2004 11:32 AM
Copyright ©1999-2019 diyAudio
