Hitachi HA-4700 Repair and Restoration
Thread Tools
Old 22nd May 2019, 12:31 PM   #1
ubergeeknz is offline ubergeeknz  New Zealand
Default Hitachi HA-4700 Repair and Restoration
Hi All,
Fairly new here 😁 thought I'd share here some of my story repairing and restoring a "parts" HA-4700 from TradeMe. If anyone's interested.
When I got it, the lights were on but there was no output at all.
What I found was one channel with the output emitters sitting around 8v, the other at the + rail more or less. Dead output on that one I thought. But it turned out that every single 1/4w "fusible" resistor in the thing was either high Z or open. This was the same problem as was found in the excellent YouTube video by JoulesperCoulomb which was what prompted me to start checking them.
Replacing them all with standard metal film resistors ("fusible" resistors in those values proved hard to come by and normal metal film resistors should work well enough at failing open if need be) brought it to life except for a several megahertz oscillation (another problem also found in the video! These must be reasonably common issues) which was due to some of the (weird) axial caps gone bad. Replaced those with mlcc type and that sorted it! Adjusted the bias and DC offset and was away. A few dry joints fixed along the way and of course new thermal paste for the power trannies.
Knowing it was serviceable, I moved onto cosmetics, restoration and tidy up. So far
* Replaced 8200uF bulk caps with 10000uF CDE caps. They actually tested fine at over 7000uF apiece but 8200 seemed kind of small for a 50W amp anyway.
* Replaced dead "TAPE" bulb with yellow LED
* Replaced incorrect 1N4004 diodes on indicator/selector board with the correct 10v zener
* Removed case bottom for corrosion and paint repair
Still to do:
* Replace other indicators with LED
* replace a switch I broke 😭 which is going to be tricky
* polish up the chromed buttons and knobs best I can, they're a bit corroded (green spots)
* Clean up rust on case and repaint
* Clean up rust on transformers and paint
* Receive new volume knob (was missing)
* Reassemble!
If people are interested I have loads of photos so... Let me know if you wanna see them.
Here's some pics of the state I got it in... Fairly rough:
"Parts" Hitachi HA-4700 Original State - Google Photos
Old 22nd May 2019, 02:02 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Is the thing working in its original state, after replacement of faulty parts?
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 22nd May 2019, 08:14 PM   #3
Yes it is working after replacing just the 1/4w resistors and a couple of capacitors (the Miller caps near the inputs of the output stage) and touching up a few dry solder joints. I suspect there is a tendency in these to build up heat between the heatsinks in the output amp stage, especially if something else is sat on top, the case has a very low profile and there aren't many other places for the heat to escape. This unit was assembled here in NZ, at least partially, this will be due to tough import levies in place at the time.
Old 22nd May 2019, 08:30 PM   #4
I work repairing inductrial equipment here in Argentina, and it is very common problem the solder joints fatigued and broken, with intermitent contact.
The question arises because I was to suggest that previously to start modding, was better to put it working as is, and once the thing jobs OK, then start modding. In any case, try one at time, so it is easily to go back if something goes wrong.
Old 22nd May 2019, 08:47 PM   #5
Exactly my approach Hitachi HA-4700 Repair and Restoration
Old 22nd May 2019, 08:50 PM   #6
Here it is working after the minimum repairs, playing some DSOTM at "hi neighbour" levels in my garage Hitachi HA-4700 Repair and Restoration
Shared album - Dan Capper - Google Photos
Old 23rd May 2019, 09:13 AM   #7
Did some rust stripping tonight... Must have been dripped on Hitachi HA-4700 Repair and Restoration there's even a hole. I've worked on cars with less rust Hitachi HA-4700 Repair and Restoration
Old 1st June 2019, 03:19 AM   #8
Between much difficulty in replacing the switch and trying to figure the best way to tackle the very rusted out top cover, I decided I would polish the buttons. First some ultra fine steel wool to take off the corrosion spots, then a car polish, then turtle wax scratch and swirl remover which is a fine polish and wax finish. Turned out not bad. Still need to do the smaller ones and tone controls when I get time, but should be easy.IMG_20190601_140237.jpgIMG_20190601_141354.jpg
Old 2nd June 2019, 08:38 AM   #9
Today, as I wait for new switches since the small ones I ordered aren't going to work, I replaced the remainder of the input selection indicators with LEDs. Turned out fairly neat I think. I also gave the front panel a light polish and wax. Looks like one side of the plastic trim needs retrobrite, I may attempt it tomorrow if the weather stays good and I can find what I need.IMG_20190602_154846.jpgIMG_20190602_164313_126.jpg
Old 2nd June 2019, 08:55 AM   #10
Since most of the other photos are just Google links I'll post them a few here for completeness...
1. Small buttons mostly polished
2. Transformers stripped and painted
3. Whole unit after changing the bulk caps
4. Old busted fusible resistors in the power amp
5. One channel with new resistors installed
IMG_20190601_210903.jpgIMG_20190523_205955.jpgIMG_20190522_225001.jpgIMG_20190409_220958.jpgIMG_20190511_144730.jpg
Hitachi HA-4700 Repair and RestorationHide this!Advertise here!
Thread Tools
Grundig RPC 450 HIFI Studio - Repair & Restoration MaximusMKD Solid State 27 16th October 2019 12:38 PM
Yamaha A1 parts for repair / restoration Joschl Swap Meet 7 30th September 2016 12:30 AM
turntable repair/restoration wertz Analogue Source 0 27th May 2015 01:30 PM
Hitachi Ha-4700 JensRasmussen Solid State 27 17th August 2014 08:08 PM
Sansui AU-X517R repair and restoration Topy44 Solid State 4 1st June 2012 05:07 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
