Marantz 250 help
Marantz 250 help
Old 18th May 2019, 01:43 AM   #1
murillollirum is offline murillollirum  Brazil
Default Marantz 250 help
Need help finding out where to put the probe to get the bias measurement. I tried putting them at the collectors case as indicated at the 250M (mine is a 250) but can not get any voltage, also across the 15ohms resistors (48v there). I think the bias it's high cause the outputs are very warm. I tried the 10W adjust as Marantz advises but wanted to use my voltimeter and adjust to 22mV instead.
The second question it's about the damm VU meters. The left one it's totally dismantled, I only have the needle and the outside case, can I adapt another complete magnet and just change the needle?
IMG-20190517-225004-01-01-1 imgbb.com
Old 18th May 2019, 07:00 PM   #2
llwhtt is offline llwhtt  United States
Measure across the .15 Ohm emitter resistors, a probe on each side of the resistor. Both the 250 and 250M should be the same.
Craig
Old 19th May 2019, 12:54 AM   #3
Thx Craig.
Marantz 250 helpHide this!Advertise here!
Marantz CD94 / Marantz CD 65 Gold -- What DAC? poynton Digital Source 5 25th August 2017 01:07 PM
Marantz CD 63/ PCM 63P-J east electronics Digital Source 1 22nd January 2016 04:19 PM
Right speakers for Marantz PM8000 + Marantz CD67-OSE? betto80 Multi-Way 2 24th May 2005 03:21 PM
Link Between Marantz CD12 and Marantz CD99 Mesh Digital Source 16 7th November 2003 06:08 PM
Copyright ©1999-2019 diyAudio
