JLH Enhanced 15W Kit: Lost instructions....
Old 15th May 2019, 12:50 PM   #1
mikmm is offline mikmm
Default JLH Enhanced 15W Kit: Lost instructions....
hi,
Many years ago, I built this Hart Kit.for my son.
When he married, he left it with me and it has been unused for ages.
As a project I have decided to bring it back into use and do some upgrading.
I have misslayed the build notes and cannot remember how to do the set-up...
There are so many pages of jlh threads that I am finding it confusing to decide what to do.
Can anyone supply me with a copy of the original Hart notes for the kit, please?
Amp is 15W with 22,0,22 supply and 4.7v zenner and 15v regulator in cct.
Many thanks,
MICK
Old 15th May 2019, 02:41 PM   #2
gannaji is offline gannaji  India
gannaji's Avatar
If there is a PCB, please post the photos, both sides, list out the BJTs and how many each. This will help others to identify.
www.samritatrust.org
Teach me the glorious lesson that occasionally, I might be mistaken. Keep me reasonably sweet.
Old 15th May 2019, 08:39 PM   #3
Thankyou for the prompt reply.
The amplifier is working but I need to check the mid point voltage and the quiescent
current and I cannot remember the correct point for metering...
RV1 and RV2 are thr relevent pots.
Here is an exact copy of the cct as built.
The pcb's are in the chassis and I do not want to remove them at this stage.
MICK
Ooops. Sorry, I do not know how to insert the picture...
Google: http://www.kaschei.com/classa/jlh1996.pdf
Page 7 shows it....
Old 15th May 2019, 10:09 PM   #4
rayma is online now rayma  United States
For midpoint (offset) voltage, connect an 8R dummy load, and measure the DCV across it.
Adjust for 0VDC.
For idle current, connect a DVM across the 0.33R and set to the desired current, I = Vmeas / 0.33R.
If you want 2A idle current, adjust for a voltage of 2A x 0.33R = 0.66VDC.
Old 16th May 2019, 08:02 PM   #5
Hi, rayma,
Thanks for that info. That is exactly what I needed...
there is clearly a difference in temperature between right and left amp. The left one is quite a bit warmer than the right...
I'll get on to that in the morning.
MICK.
JLH Enhanced 15W Kit: Lost instructions....Hide this!Advertise here!
GAS Grandson - Bongiorno enhanced spocintosh Solid State 43 24th February 2019 10:01 AM
Enhanced Triode PP Amp Vortex Tubes / Valves 29 22nd February 2019 09:08 AM
SS driver circuit / Enhanced OP-Amp the_manta Solid State 3 4th June 2014 10:50 AM
Enhanced Print View gustin Forum Problems 13 24th May 2013 08:22 PM
John Broskie's enhanced T8 CarlyBoy Tubes / Valves 13 8th October 2006 06:13 PM
Copyright ©1999-2019 diyAudio
