B&K Components 125.2 Repair Assistance - DC voltage speakers terminal
Old 13th May 2019, 01:18 AM   #1
vicsd is offline vicsd  United States
Default B&K Components 125.2 Repair Assistance - DC voltage speakers terminal
Hello,
This is is my first post on the forum. I am new to power amp repair and not sure where to start the checks. Looking to repair the B&K components 125.2 power amplifier.
The amplifier speaker terminals reflecting DC voltage (rail) of 70 V on both channels. At first checked all capacitors and resistors. Also, I have replaced the all output MOSFETS but the issue still persist.
Thank you in advance,
Old 13th May 2019, 05:49 PM   #2
Mark Tillotson is offline Mark Tillotson
Both power rails are up?
I would take care with +/-70V, thats 140V in total. But you'll need to measure the voltages on the LM4702 inputs and outputs - I'd start by checking the bias voltages between J1 and J2, and J3 and J4. (the outputs).
If the outputs are high one a channel the non-inverting(+) input should be at a higher voltage than the inverting(-) input. If not that LM4702 is toasted. If so then the feedback circuit is misbehaviing and the loop isn't closed.
Old 14th May 2019, 12:48 AM   #3
Hello Mark,
Both rail are up. Power Supply PCB has +70V/-70V going to iZone board.
This is two channel amp, so only J1 and J2 are present. Both channels shows positive voltage:
J1 +67.46 V
J2 +68.0 V
I will measure the voltage on U1 and post the results.
Old 14th May 2019, 06:03 PM   #4
The bias is backwards by the look of it.
J1 and J2 are part of one channel, so you must have J3 and J4 on the other channel?
Old 15th May 2019, 04:28 AM   #5
I've measured the voltage values on the U1.
Pin13 + 68.2
Pin14 + 67.8
Pin15 - 68.3
Pin2 +67.5
Pin3 +67.6
Pin5 +67.7
Pin6 +67.8
Old 15th May 2019, 06:11 PM   #6
R2 open circuit perhaps? The inputs are matching the outputs so clearly very little is pulling them down to ground. Could be internal fault or the feedback network.
Old 16th May 2019, 04:42 PM   #7
Ordered replacement for U1. Will post an update once installed. Thank you Mark.
B&K Components 125.2 Repair Assistance - DC voltage speakers terminalHide this!Advertise here!
Assistance please..in need of Alpine MRP-M650 repair schematics/manual 1isenuff Car Audio 0 6th March 2019 05:11 AM
Denon PMA 2000 IVR Repair assistance required dhole Solid State 4 4th November 2015 09:15 AM
RF 200ix amp repair assistance mpednault Car Audio 16 11th October 2012 12:43 PM
Assistance on B&W DM1200 crossover repair? llimbo Multi-Way 4 27th May 2011 05:09 PM
Copyright ©1999-2019 diyAudio
