How to wire up an Amplifier
Old Yesterday, 03:05 AM   #261
stuartmp is offline stuartmp  Australia
If you don't mind could you please answer post #254.
Old Yesterday, 11:02 AM   #262
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
The chassis must always be earthed - and especially so in any DIY stuff since DIY'ers (and that's me with my DIY hat on also) don't have the money or the wherewithal to undertake the testing and certification a double insulated product demands.
The 0V of the amplifier PSU must either go directly to the chassis earth point (and there is only ONE chassis earth point in order to avoid ground loops) OR it can go through a suitable Ground Lifter.
If the mains is diverted in any way from the live neutral as would be the case if the live or neutral touched the chassis or some part of the amplifier PCB, the GFI (Ground Fault Interrupter) will trip. You only need a few mA of imbalance for this to happen and the GFI usually responds to this type of fault within 2-3 mains cycles.
The GFI is designed to protect against electrocution.
On the mains side, the first thing the live feed has to encounter is a fuse, then a switch and from there to the transformer primary and any mains filtering etc.
The fuse is there for fire protection arising from a potential overload or short within the equipment.
re the ground lifter:- do not use a Ground Lifter unless you are absolutely sure the equipment will be used in tandem with an electrical system that specifies a GFI. These are mandated by law in most advanced economies, but this may not be the case in some other areas - check your local regulations.
Further, I recommend a 35A bridge rectifier for the Ground Lifter job. The surge rating is typically 5-10x the average current rating for a specified number of mains cycles.
re AndrewT's original test that caused the mains fuse to blow:- If the live for example touched the amplifier 0V on the secondary side or to the chassis, two things would be going on. Firstly, the current flowing to Earth (either through a Ground Lifter or directly if there was none) would shoot up into the many 10's of amps, and on a system with low loop resistance on the mains side, potentially 100's of amps. A 'T' type fuse would limit the amount of time this condition could persist to a few mains cycles as it appeared happened in his test. Secondly, the GFI would be detecting a massive imbalance in the live<>neutral currents and it would trip. GFI's typically trip in 40-60ms and would probably go before the mains fuse. I don't recall the details of AndrewT's original test - I don't know if he mentioned if the GFI had tripped, but its likely it would have as well as the fuse popping.
So, this is why the Ground Lifter Diodes/Bridge should be rated to carry the full mains trip current for a few hundred ms - if it popped, the user would reset the mains and now have an appliance where the mains could touch something on the secondary without it tripping the GFI until someone touched it of course, and then the GFI would trip - but, that is still not considered safe or acceptable.
How to wire up an AmplifierHide this!Advertise here!
FS: The Wire SE-SE headphone amplifier OlegSh Swap Meet 11 17th July 2017 06:06 PM
Correct way to wire amplifier thommio Class D 4 16th March 2017 04:51 PM
WTB: The Wire headphone amplifier PCB Rodeodave Swap Meet 8 4th December 2012 11:19 AM
how to wire VU meter on amplifier? milen007 Parts 13 26th July 2009 06:52 PM
Amplifier is a piece of wire Bigun Solid State 3 5th May 2009 03:33 PM
Copyright ©1999-2019 diyAudio
