Easy-MOS is a simplistic, efficient and evolutive all-MOS amplifier for beginners
Old 5th May 2019, 02:47 PM   #21
gannaji is offline gannaji  India
gannaji's Avatar
Tracerphone thread !
Dear Daniel,
Ref please !
--gannaji.
www.samritatrust.org
Teach me the glorious lesson that occasionally, I might be mistaken. Keep me reasonably sweet.
Old 5th May 2019, 05:37 PM   #22
Elvee is offline Elvee  Belgium
Elvee's Avatar
Here it is:
A small, low-voltage, battery operated amplifier
. .Circlophone your life !!!! . . ♫♪ My little cheap Circlophoneİ ♫♪
Electrify your daily life!!! ....⚡⚡ ELEKTRIA ⚡⚡
Old 6th May 2019, 05:07 AM   #23
gannaji's Avatar
Oh ! Thank you !
Old 7th May 2019, 04:45 PM   #24
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Is there a 'best practices' way to put both left and right channels from the source, with minimal cancellations, into an EZmos mono amp? The 40's and 50's standard of mono in the corner, had a broader sweet spot, and was really tidy. I'm thinking, add tablet, get jukebox.
Old 7th May 2019, 05:19 PM   #25
Elvee's Avatar
One advantage of an inverting configuration is that it is a stub of a mixing desk: simply duplicate C1/R12 input network n-times, and you get a clean n-input mixer, with low interaction between channels.
You can chose to multiply R12's value by n or keep them at 10K depending on input levels.
You can even make them variable.
Depending on the audio material and the way it was recorded, there might be cancellations at some frequencies, but that's kind of inevitable.
If the channels are mixed at the acoustic level (two speakers), cancellations will also occur, but they will probably be less sharp, and vary depending on the listening position.
With an electrical mixing, the cancellation will be completely independent from the listening position
Old 7th May 2019, 06:01 PM   #26
Mark Tillotson is offline Mark Tillotson
Originally Posted by Elvee View Post
Because of the non-symetrical topology and the low feedback, low-order, even harmonics tend to be dominant.
Here is the THD residue (0.15%) together with the output signal:
Well that's predominantly 3rd harmonic on screen, so I'm unconvinced by the spice values...
Old 7th May 2019, 07:21 PM   #27
Elvee's Avatar
Well, neither am I, but that's the untampered reality, and to be honest the PMOS I used is different from the sim.
I tried to use a P-type that minimized the overall dist, because that's in fact what I prefer (except if the residue is something like Xover dist, which I hate).
This also explains why the measured THD is lower than the simmed one, a moderately rare instance.
Because complementarity does not actually exist for P or N MOS transistors, you are ~free to chose the ones that give you your preferred profile.
Another way of altering easily the profile is to make the source resistors different: it works in sim, and it will also work in reality (I didn't try it, but I am confident it will)
Old 8th May 2019, 03:48 AM   #28
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by danielwritesbac View Post
Is there a 'best practices' way to put both left and right channels from the source, with minimal cancellations, into an EZmos mono amp? ....
Two resistors.
There's no sensible alternative.
Old 8th May 2019, 09:25 AM   #29
anti is offline anti  Slovakia
Originally Posted by PRR View Post
TWO resistors.
Let's see ... ONE trimpot?
(a potentiometer with a knob would be a little bit arrogant in this case imho, but who knows...)
Old 8th May 2019, 12:49 PM   #30
kokoriantz is offline kokoriantz  Lebanon
Consider for the input stage the ssm3k339 and use floating single supply as sublimed JLH1969
Easy-MOS is a simplistic, efficient and evolutive all-MOS amplifier for beginnersHide this!Advertise here!
QUASI Amplifier for Beginners apexaudio Solid State 892 26th September 2019 08:51 AM
Efficient Subwoofer Amplifier moschfet Solid State 21 25th November 2012 04:13 PM
OLD THREAD Simplistic Mosfet HV Shunt (The Simpler Simplistic Design by Salas) quanghao Quanghao Audio Design 460 6th May 2012 11:13 PM
PCB for QUASI Amplifier for Beginners with changes!? radio Solid State 4 18th August 2011 08:59 PM
Copyright ©1999-2019 diyAudio
