Erno Borbely "Milennium" All Fet Class A Power amp 75W RMS
Old 15th April 2019, 03:09 PM   #11
alweit is offline alweit  Israel
Yes, it should work - replace R11, R12: instead of 75R put 50R and use 100R trimmer.
Old 15th April 2019, 03:37 PM   #12
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
I don't have an50 ohm resistort, still can't set the offset voltage to 0V with P3.
Old 15th April 2019, 03:50 PM   #13
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
For a better precision, you can put the pot in parallel of a resistance that bot give the original pot value required.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 15th April 2019, 04:09 PM   #14
If you look at schematic, you can see that it is symmetrical, resistors R8, R9 - 100 Ohm,
R11, R12 - 75 Ohm, P3 - 50 Ohm, so R8 + R9 = 200 Ohm, R11 + P3 + R12 - also = 200 Ohm, you cat put 200 Ohm pot instead of 50 Ohm (P3) and short R11 and R12, or, as I offer, put 100 Ohm instead of P3 and replace R11 and R12 with 50 Ohm (closest 49.9 Ohm) resistors - it will keep symmetry. If you put 25 Ohm instead of 50 Ohm trimmer,
you should use R11, R12 value 175 / 2 = 87,5R (closest 86.6 Ohm), in my amp the P3 is almost in the center, so I think 25 ohm will be enough - I selected all components very carefully with curve tracer - but I do not know about yours.
Old 15th April 2019, 08:28 PM   #15
That's a good idea, I will try P3 trimpot 100 ohms + parallel 100 ohm fixed resistor.
If Osvaldo idea doesn't work I will try P3 200 ohm shorting R11 R12.
Thanks for support guys.
Good night
Felip
Old 17th April 2019, 02:50 PM   #16
I have problems now with the regulator, in the plus side I'm measuring -5Vout, the regulator input is OK +55V but when I measure voltage across D17 is 0V in place 6.9-7V, I desoldered the voltage reference diode from the PCB and measured with DC75 and says is OK
The measuring is done connecting both rails positive and negative (+Vs2 & -Vs2) to the driver, SGND to PGND (Driver) and PGND from PSU PCB to PGND (Driver) so only disconnected from output section: FB, +D & D-
I guess wasn't necessary to connect the output section to the driver?
I desoldered all diodes & FETS of the plus side of regulator and all the devices are OK. Can be P5 damaged?
File Type: jpg Millenium All-Fet Regulators EB-2000-342 001.jpg (379.9 KB, 122 views)
Old 17th April 2019, 03:20 PM   #17
P5 is OK
Old 17th April 2019, 03:23 PM   #18
Done paralleled the pot with a 100 ohm but I have now problems setting the regulator to +50V
Old 17th April 2019, 07:29 PM   #19
Ref. diode D17 is OK 6.9V
Voltage across D15 0,7V, the other power amp D15 2.7V
Old 17th April 2019, 09:35 PM   #20
Is it possible that D16 is damaged - this is current regulator diode (J508 2 mA). You can remove it from the board and easily check - connect milliampermeter in serial with it and apply ~10V - (of course take care about diode polarity) - milliampermeter should show 2-2.5 mA, if not - the diode is damaged. If you do not have spare one, it is possible to replace it with ~22K resistor, but in this case you should connect electrolytic capacitor 22-47 uF in parallel to C27 to protect voltage reference (LM329) at start point - I offer to to it only fo test, you still need to find J508, if it is damaged.
Erno Borbely "Milennium" All Fet Class A Power amp 75W RMSHide this!Advertise here!
Erno Borbely super shunt regulator Sunsun22 Power Supplies 17 20th January 2019 05:36 PM
FS Erno Borbely EB-803/214 Triple PSU/regulator merlin el mago Swap Meet 3 5th March 2018 12:21 PM
FS: Erno borbely complete I/V (I/V+PS+REG+Tx) merlin el mago Swap Meet 32 4th December 2017 01:36 PM
Erno Borbely 199/320 All-Fet phono preamp PoweRex Analogue Source 10 26th October 2016 09:00 AM
Has anyone used Erno Borbely EB-201/168 ANALOG GUY Solid State 14 8th February 2006 10:26 AM
Copyright ©1999-2019 diyAudio
