Bryston 4B SST clone
Old 23rd May 2020, 02:17 PM   #441
amplidude is online now amplidude  Denmark
They might work, but the bryston is made with " slow" transistors mjl21193/94 are 4mhz the mentioned are 30 mhz, you might end up with a high power oscillator, but nothing some pf bypass caps couldn't handle.
Old 23rd May 2020, 02:50 PM   #442
chalky is offline chalky
I tried making ( as opposed to simulating ) a Bryston style output stage with bjts driving lateral mosfet output devices and it oscillated nicely. The trick is to ensure stability without completley killing the hf performance - sometimes that's not so easy.
If it ain't broke don't fix it
Old 23rd May 2020, 06:13 PM   #443
Absolutely right, it's all about giving and taking.
Old 23rd May 2020, 07:47 PM   #444
hschier is offline hschier  Chile
Between gate and earth?
Old 23rd May 2020, 08:10 PM   #445
I think something like 100pf in series with 100R between gate and drain would be a good place to start. With mosfets you can also slip a ferrite bead on the gate lead in lieu of or as well as a gate stopper resistor. Some people don't like ferrite beads but they work for me. Thing is if you're going to use different parts you need to be prepared to experiment - preferably using a power supply with an adjustable current limit.
Old 23rd May 2020, 08:21 PM   #446
You could also start with lower value, say 33pf, se its stable , if not increase, and yes beads work, I had trouble with greg ball ska amp, and they helped.
You should aim for lowest value possible
Old 23rd May 2020, 08:42 PM   #447
josejuancano is offline josejuancano  Spain
Default diameter of the inductor
Friends, what is diameter of inductor L1, seller an boom list ask 1,8mm cooper wire nameled and 10 turns but not speak diameter, you know something?
Old 24th May 2020, 09:17 PM   #448
when you said stable you mean not distortion?
Old 25th May 2020, 08:59 AM   #449
Default Transformer T1 pcb filter
Friends what buy transformer compatiblity for this pcb 220v/ 12v encapsulated, thanks
Old 25th May 2020, 10:34 AM   #450
With stable I mean , no oscillation, lower value capacitor means better hf performance, and as chalky said it has to be a rc.
Bryston 4B SST cloneHide this!Advertise here!
Bryston 4B ST Clone Started rsbonini Solid State 30 12th November 2019 03:35 PM
Bias vs. heatsink temp on Bryston 4BSST jimangie1973 Solid State 19 29th September 2010 12:06 AM
bryston clone mak müh Solid State 14 16th December 2009 08:48 AM
Bryston 3B/4B-SST clone? taj Group Buys 3 9th December 2006 07:46 PM
Looking for a Bryston 4B ST clone Phil O.son Solid State 5 6th November 2002 08:36 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
