Bryston 4B SST clone
Old 10th May 2019, 03:45 PM   #11
chalky is offline chalky
Here's some photographs of my input stage build. Its complete except for the phono sockets, which are en route from China. As you can see I'm not the worlds greatest photgrapher but there's enough detail to see whats involved
If it ain't broke don't fix it
Old 10th May 2019, 04:25 PM   #12
amplidude is offline amplidude  Denmark
Looks great chalky, yes the rca is not the easiest part to find, I was considering moving the input connectors of pcb, I read some reviews of original Bryston, peoplo complained about the rca connectors because they could break.
Sat for 15 minutes with output board, seems that if I lift one leg of each constant current diode, the voltage drop over r24 r60 is within spec, am puzzled as to why, need more time and more coffe.
Keep up the good work chalky, the pics aren't as bad as you say
Old 10th May 2019, 06:44 PM   #13
Differences between Bryston 4bsst input stages and clone:-
1) The input amplifier of the Bryston has switch selectable gain of 1.5 or 2 whilst the clone has a fixed gain of 3.
2) The clone has back to back diodes across the inverting and non-inverting of the input amplifier whereas the Bryston does not.
3) The input of the Bryston is dc connected but the clone uses a 68uF electrolytic capacitor
4) Signal ground is connected to chassis ground via a paralled 100nF capacitor and 220R resistor on the clone; whereas the Bryston connects the star ground to the chassis ground via a paralled 100nF capacitor and 100R resistor bridged by two series connected pairs of back to back diodes ( implemented by a suitably connected 35A bridge rectifier).
5) The clone has no guidance on how to deal with pin 1 on the xlr connector. In particular some xlr sockets have (removeable) strap between pin 1 and one of the chassis mounting holes ( connects pin 1 to metal chassis when you insert metal screw) and some do not. Those that do will short out the 100nF capacitor and 220R resistor mentioned in 4)
6) The +/- 33v supplies to the input amps are obtained slightly differently in each case.
There are probably other differences that I haven’t spotted yet.
Old 10th May 2019, 06:51 PM   #14
Amplitude, If you lift one leg of the constant current diodes you won't get any +/-33V outputs from the regulators for the power amp front end. Have you set the bias generator preset for max resistance yet?
Old 10th May 2019, 06:53 PM   #15
Yeh I saw the same comments about the RCA connectors. I'll probably keep them on the pcb and work out a way of relieving the strain.
Old 10th May 2019, 08:12 PM   #16
asuslover is offline asuslover  Romania
Any way u can post the schematic? Curious about this amp.
Old 10th May 2019, 09:09 PM   #17
Probably not. The ebay seller doesn't publish the schematic but emails the details when you buy the pcbs. However Bryston publish the schematics of their amps here Technical Documents - Bryston so youcan easily find the 4B SST. The "clone" we're talking about is very similar to the real thing.
Old 22nd May 2019, 01:21 PM   #18
Any luck fixing your output board yet amplitude? I haven't done much recently since I brought back a very virulent cold after babysitting grandchildren for a week. More soon
Old 5th June 2019, 04:57 PM   #19
Finally got back to work on my 4bsst klone - got interrupted by a nasty bout of genuine influenza. I finished the input board and everything tested fine. There's a small gotcha if you test the input board by itself - the signal ground and the stabilised power supply ground are not connected on the pcb. So if you, like me, use a floating power supply as input to the pcb stabilised power supply then there is no common ground and the input board does not work. A temporary wire bridge fixes this. The overall gain of the input board from the phono input is x2 not x3 a I previously stated.
The discrete component opamp has a gain of x3 but there is x0.667 attenuation at the input so overall the gain is x2. The real Brystons have their phono input sockets attached to the pcb and not the metalwork, so there is a point of weakness. The klone phono sockets are soldered to the pcb but also have mounting nuts to fix them to the back panel, so no weakness there. You can see this in the attached photograph. I ran a quick fft spectrum analysis with the input board producing a 1v rms output at 1kHz and any distortion was lost in the noise. I probably could have dug distortion out of the noise if I averaged for long enough but with a figure of well under -100dB I wasn't inclined to bother.
As well as documenting my build of the Bryston 4bsst klone I intend to redesign both the input board and the power amp board. The power supply and protection board will remain unchanged. Why bother to do this when I'm sure the klone will measure and sound fine? Well the input board and the input/vas of the power amp board use a common discrete component symmetrical opamp design which performs fine, but can definitely be improved. The opamp has npn and pnp input long tailed pairs and the collector currents of neither pair perfectly balanced - close, but far enough apart to give rise to small extra distortions.
The choice of push pull vas transistors in the power amp is sub optimal and suitable replacements will yield further small reductions in distortion, particularly at hf. The thermal tracking of the Vbe multiplier needs some investigation ( it may be ok ) and the circuitry around the quiescent current setting potentiometer needs to be put back to something resembling the Bryston original. Otherwise its far too easy to blow up the output devices unless the pot is set correctly before switch on. I'll redraw the original discrete component opamp circuit and aslo sketch out some alternatives. For the moment I intend to leave the output stage of the power amp as it is.
Old 5th June 2019, 05:04 PM   #20
Almost forgot, no degeneration of input ltps either.
Bryston 4B SST cloneHide this!Advertise here!
Bryston 4B ST Clone Started rsbonini Solid State 30 12th November 2019 04:35 PM
Bias vs. heatsink temp on Bryston 4BSST jimangie1973 Solid State 19 29th September 2010 01:06 AM
bryston clone mak müh Solid State 14 16th December 2009 09:48 AM
Bryston 3B/4B-SST clone? taj Group Buys 3 9th December 2006 08:46 PM
Looking for a Bryston 4B ST clone Phil O.son Solid State 5 6th November 2002 09:36 AM
Copyright ©1999-2019 diyAudio
