LME49830 in TINA
LME49830 in TINA
Old 6th March 2019, 10:54 PM   #51
kokoriantz is online now kokoriantz  Lebanon
Yes , the generator is low distortion 20Mhz sine ,triangle, square and the frequency can be sweeped by the spectrum analyzer . You can observe the frequency/phase response of the circuit while adjusting it. How I regret not to have it .
Old 15th March 2019, 04:32 PM   #52
UltimateX86 is offline UltimateX86  France
LME49830 in TINA
Originally Posted by kees52 View Post
this output stage does give extra gain, it is a compound with gain. the irf driver can also be a bjt then it is a hybrid. quite liniair too. regards
Hello, What do you use as driver on this compound with ECW20N20 ? Waiting to have my oscilloscope to test the lme49830 without output, I simulated some discret amp based on yamaha circlotron : Nextcloud circlotron diyaudio I created a public space on my site, where we can upload and read file ... for diyaudio the root directory : Nextcloud diyaudio
www.circlotron.audio
Old 15th March 2019, 06:13 PM   #53
kees52 is offline kees52  Netherlands
The lateral mosfet has quite low gate capacitance, so this need not such a big driver, do you want use a bjt (hybrid) or a mosfet for drive? for both it is not critical, but how better the current to drive the wider the bandwith afzuse, a 500 mA to 1 amp is enough, or the irf610 ir itf 6910 mostet as drive what I did.
regards
Old 15th March 2019, 06:44 PM   #54
LME49830 in TINA
I prefer bjt for low capacitance but mosfet should be more stable ?
Old 15th March 2019, 06:58 PM   #55
LME49830 in TINA
Have you seen this?
Not compound but a solution to bias
Circlotron—Once Again
Old 16th March 2019, 08:03 PM   #56
I have already, somewone did help me also with that, but do is now not active because of work home.
regards
Old 16th March 2019, 08:05 PM   #57
Mosfets are more prone for oscillation because of gate capacitances, who can couse fase shift, so proper idle current driver do work keeping fase to zero.
Old 16th March 2019, 08:37 PM   #58
Here some changes, just sim.
put in a compound output, one with njt driver and one with mosfet, last has less distortion..
Old 16th March 2019, 10:24 PM   #59
LME49830 in TINA
thank you
could you post a version with 35v on output and with model in the schematic ?
with model i found, i have more distortion with mosfet
could you keep 20n20 for output mosfet ?
the ksa1220 must not be better driver than mje ?
.MODEL KSA1220 PNP IS=4.7863E-13 BF=289.3 BR=9.76 NR=1.006 ISE=5.2481p NE=2 ISC=2.4909E-11 NC=1.5 VAF=98.5 VAR=6.7 IKF=2.7061 IKR=0.0759 RB=2.26 RBM=0.2308 IRB=0.001 RE=0.1908 RC=1.1748 QCO=0.02 RCO=3.9811 VO=11.078 GAMMA=5.01187E-8 CJE=3.4786E-10 VJE=0.9575 MJE=0.4694 FC=0.5 CJC=1.1224E-10 VJC=0.5761 MJC=0.4365 XCJC=0.4955 XTB=1.7978 EG=1.2255 XTI=3
Old 16th March 2019, 10:35 PM   #60
LME49830 in TINA
i have 3amp on output mosfet OUCH
LME49830 in TINAHide this!Advertise here!
Tina-TI calculations Lojzek Software Tools 2 24th January 2019 03:02 PM
TINA Vs. Multisim Count Tubeula Software Tools 9 25th November 2014 09:55 PM
TINA Slow? richie00boy Parts 18 24th September 2014 09:30 PM
Tina Cloud anyone? jackinnj Software Tools 0 28th May 2014 05:15 PM
TI Tina ctardi Chip Amps 5 17th January 2010 12:47 PM
Copyright ©1999-2019 diyAudio
