LME49830 in TINA
LME49830 in TINA
Old 5th March 2019, 08:40 PM   #21
UltimateX86 is offline UltimateX86  France
LME49830 in TINA
I had a lot of difficulty to bias with a CSS, this amp is a good base for a futur amplifier
now lme
www.circlotron.audio
Old 6th March 2019, 12:07 AM   #22
kokoriantz is offline kokoriantz  Lebanon
Just bias with a battery on one output . It works . I will order a pair of this and try out in bridged single supply . Thanks for the spice models , I wonder how you could find it .
Compensation input doesn't work neither. I couldn't find bellow 40$ a pair , too expensive for me to try it out.
Old 6th March 2019, 07:47 AM   #23
LME49830 in TINA
Hi kokoriantz, could you give me your file with lateral mosfet?
I added a battery in mine and mosfet current dont change
thanks
Old 6th March 2019, 07:56 AM   #24
Biased 782ma .
Old 6th March 2019, 08:04 AM   #25
LME49830 in TINA
Ok thanks but i dont have your file :
C:\Users\exr\Documents\2sk1058.mod
C:\Users\haik\Documents\2sj162.mod
Old 6th March 2019, 08:16 AM   #26
LME49830 in TINA
unless you know how to add this in tina:
File Type: txt Hegglun Model Notes.txt (856 Bytes, 3 views)
Old 6th March 2019, 10:50 AM   #27
put the TSM files in macrolib folder where you will put other spice models later. In Tina, apply insert/macro and show the files, the transistors will be inserted in the circuit .The other files to change txt to mod .
File Type: txt 2sj162.txt (537 Bytes, 3 views)
File Type: txt 2sk1058.txt (534 Bytes, 3 views)
Old 6th March 2019, 11:17 AM   #28
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
LME49830 in TINA
This is an interesting IC and looks very useful. I have not used it before but looking at the data sheet it appears that the N and P connections need to have a sense resistor to tell it how much current is flowing. As you are using this in a Circlotron mode and leaving the “P” not connected, there is no current to sense and the IC probably has one of its safety features now active to prevent damage.
Try setting it up in spice per the recommended schematic to see if it models correctly. My guess is that you need a Rq. You might be able to fool it by connecting P from each across (in an X crossover) a Rq strapped across the the gate stoppers for the N channels? But most likely, you cannot use this in a Circlotron as it is designed for consumer (single function) push pull amps.
File Type: jpeg FEBC61BC-A243-4624-8F10-4DF8A6EC233C.jpeg (113.4 KB, 60 views)
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 6th March 2019, 11:26 AM   #29
in snam126 zip folder you find lme49830.TSM file ,add it also to macrolib folder to add a second one .
Old 6th March 2019, 12:06 PM   #30
LME49830 in TINA
xrk971,
The resistance RQ 12k, is often absent :
LME_AMP_SCHEMATIC.pdf - Google Drive
http://forum.vegalab.ru/attachment.p...8&d=1361379853
http://ddata.over-blog.com/1/74/30/0...Tuto_V4.03.pdf page 22
an other lateral mosfet without RQ
LME49830 Project/Boards...
LME49830 in TINAHide this!Advertise here!
Tina-TI calculations Lojzek Software Tools 2 24th January 2019 03:02 PM
TINA Vs. Multisim Count Tubeula Software Tools 9 25th November 2014 09:55 PM
TINA Slow? richie00boy Parts 18 24th September 2014 09:30 PM
Tina Cloud anyone? jackinnj Software Tools 0 28th May 2014 05:15 PM
TI Tina ctardi Chip Amps 5 17th January 2010 12:47 PM
Copyright ©1999-2019 diyAudio
