LME49830 in TINA
LME49830 in TINA
Old 4th March 2019, 09:19 PM   #11
kees52 is offline kees52  Netherlands
Just see good that the Vbe transistor in on one side reversed, it is on the negatove side of circlotron.
best is build it and test, I can not get it to work, only without bias.
regards
Old 4th March 2019, 09:36 PM   #12
Wel I have see into the model.
see the pic, bias is in model terminated, and as such not usable.
I need a model with bias, strange that this is terminated.
regards
Old 5th March 2019, 08:27 AM   #13
UltimateX86 is offline UltimateX86  France
LME49830 in TINA
texas did not give anything else
LME49830 | Mid/High-Power Class D Amplifiers | Audio | Tools & software
www.circlotron.audio
Old 5th March 2019, 09:13 AM   #14
LME49830 in TINA
I just ordered 4 * ECW20N20-S
http://www.exicon.info/PDFs/ecw20n20.pdf
Old 5th March 2019, 12:01 PM   #15
LME49830 in TINA
apart from the circlotron scheme, I've never seen that LM with lateral fet use vbe multiplier
The_Wire_LME_Lateral_FET_Amp Wiki
There is no thermal bias compensation required, and no emitter resistors needed thanks to the lateral mosfets.
Old 5th March 2019, 12:04 PM   #16
For lateral fet you need none, for irfp240 you need one, that is why we did try vertcals. But for these fets, do check if these has gate protection diodes otherwise put on yourselfs.
I have looked on the lme chip itselfs, the outputs are currend source loaded where the bias resides, in circlotron we use just one side, x 2 for the other one, if the idle voltage do not cancel out, we can set bias idle.
Laterals sound much better in mine eyes, I have try this some time ago.
regards
Old 5th March 2019, 02:20 PM   #17
And with post 16 driver you can nicely steer this compound output circlotron.
it as 2 x amplification factor, with local feedback you can make some nice stuff.
output pic is 1 x version, feedback resistors can be adjusted, you need 2 watt resistors here, or even more.
Old 5th March 2019, 02:34 PM   #18
LME49830 in TINA
Nice output stage, i already try to simulate a compound in this schematic, but no result :
http://circlotron.audio/data/simulat...otron_1.1A.asc
http://circlotron.audio/data/simulat...otron_1.1A.png
moreover I still have not succeeded in replacing RB by a bias system
Old 5th March 2019, 05:57 PM   #19
Mooly's Avatar
LME49830 in TINA
Moved to Solid State forum.
Old 5th March 2019, 08:17 PM   #20
Do work in it.
the bias can be done with a current source ? for output I have put them in, see .asc voltage will be swapped on N or a P mosfet, bias is then close to two, otherwise it has to be negative or positive, can be done with current source who is temp sensor also>?.
Have no other work, maybe look at it later.
regards
LME49830 in TINAHide this!Advertise here!
Tina-TI calculations Lojzek Software Tools 2 24th January 2019 03:02 PM
TINA Vs. Multisim Count Tubeula Software Tools 9 25th November 2014 09:55 PM
TINA Slow? richie00boy Parts 18 24th September 2014 09:30 PM
Tina Cloud anyone? jackinnj Software Tools 0 28th May 2014 05:15 PM
TI Tina ctardi Chip Amps 5 17th January 2010 12:47 PM
Copyright ©1999-2019 diyAudio
